Whirlpool 50G Gas Pilot Won't Stay On - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-29-2012, 03:45 PM   #1
I have a 10 year old Whirlpool 50 gallon gas water heater and the pilot won't stay on. I can light the pilot after several attempts, then heat the tank. But after the burner goes out, eventually the pilot goes out. A local plumber told me over the phone it probably needs a new thermocouple. Sounds like a probable solution. Is this the most likely problem? There is a panel on the lower front of the unit held on by 2 screws. Through that panel go 4 things - 2 gas lines (one flexible and one solid - one for the burner and one for the pilot?), copper thermocouple line and orange pilot sparker wire. The pilot light sight glass is also in the panel. Can the 2 gas lines be disconnected and this door removed to replace that TC?
Thanks for any and all assistance.
Dowhatican is offline   Reply With Quote
Old 10-29-2012, 04:17 PM   #2
This may be solved by tomorrow. I called Whirlpool because it has a 12yr warranty and the heater is 10yr old. They are overnighting me a free thermocouple/burner retrofit kit. Install instructions online look pretty easy.
Pilot doesn't stay lit avatar2k HVAC 13 12-08-2015 04:22 PM
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 03:55 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 04:29 PM
Pilot light does not stay on cprao HVAC 11 02-14-2010 06:38 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 06:16 PM
