Old 01-14-2013, 02:05 AM   #1
Whining toilet.
I am sure this has been asked and answered before but I cannot seem to find the thread.
My toilet moans after flushing and after the tank has finished filling. The moaning lasts anywhere from 30 seconds to 5+ minutes. The moan will go away when I turn on and off the water in the kitchen sink or bathroom sink multiple times and also if I flush. Though if I stop it with flushing it returns again after the tank is done filling. I have seen a problem similar where there is the whine while filling and the assembly in the toilet is usually the fix. This problem is after the filling when the water has stopped.
Help! This is driving us batty and guests think we have ghosts.
Keyoun is offline   Reply With Quote
Old 01-14-2013, 02:51 AM   #2
Whining toilet.
It might require a plumber on site for this but I've heard similar problems related to improper or inadequate. plumbing vents
strategery is offline   Reply With Quote
Old 01-14-2013, 07:34 AM   #3
Whining toilet.
I've seen the water pressure set to high cause this, old steel pipes.
Try one simple trick, partly close the supply valve to the toilet and see if the noise changes.
Old 01-14-2013, 09:19 AM   #4
Whining toilet.
replace the ballcock (fill valve) and that should fix it.
The Following 2 Users Say Thank You to DannyT For This Useful Post:
jagans (01-14-2013), Lightfoot (01-14-2013)
Old 01-14-2013, 01:39 PM   #5
Whining toilet.
Thank you joecaption! Turning the valve a fraction of an inch seems to have solved the problem. This has gone on for the last 6 months and the silence is sublime. Also, since I have taken all the credit I am the new hero of the family. :-)
Old 01-14-2013, 01:52 PM   #6
Lightfoot's Avatar
Whining toilet.
(we won't tell)
Joe is da' man.
Lightfoot is online now   Reply With Quote
Old 01-14-2013, 03:13 PM   #7
Roofmaster
Whining toilet.
Ill be GoTaHell. Joe, I would have never thought that could solve the problem.
Just goes to show ya. Ya larn sumpin ever dey. evn if it dont make any dang cents
" A lot of men build things, and a lot of things fall down "
Old 01-14-2013, 06:56 PM   #8
Whining toilet.
Does your toilet have a ballcock? (rod with float ball on the end) or something else such as a Fluidmaster 400A. I might suggest replacing your fill valve with a Korky Quietfill.
I've seen this happen before with old worn out ballcocks and high water pressure, the diaphragm inside will make a moaning sound during refill.
gusherb94 is offline   Reply With Quote
Old 01-15-2013, 06:36 AM   #9
Whining toilet.
sounds like the ballcock may need replacing
Click Plastics is offline   Reply With Quote
Tags
toilet, whining
Please advise on slow flushing toilet? WillK Plumbing 5 03-12-2012 10:58 AM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 12:19 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
