-   -   Whining toilet. (http://www.diychatroom.com/f7/whining-toilet-169064/)
Keyoun 01-14-2013 01:05 AM
Whining toilet.
I am sure this has been asked and answered before but I cannot seem to find the thread.
My toilet moans after flushing and after the tank has finished filling. The moaning lasts anywhere from 30 seconds to 5+ minutes. The moan will go away when I turn on and off the water in the kitchen sink or bathroom sink multiple times and also if I flush. Though if I stop it with flushing it returns again after the tank is done filling. I have seen a problem similar where there is the whine while filling and the assembly in the toilet is usually the fix. This problem is after the filling when the water has stopped.
Help! This is driving us batty and guests think we have ghosts.
strategery 01-14-2013 01:51 AM
It might require a plumber on site for this but I've heard similar problems related to improper or inadequate. plumbing vents
joecaption 01-14-2013 06:34 AM
I've seen the water pressure set to high cause this, old steel pipes.
Try one simple trick, partly close the supply valve to the toilet and see if the noise changes.
DannyT 01-14-2013 08:19 AM
replace the ballcock (fill valve) and that should fix it.
Keyoun 01-14-2013 12:39 PM
Thank you joecaption! Turning the valve a fraction of an inch seems to have solved the problem. This has gone on for the last 6 months and the silence is sublime. Also, since I have taken all the credit I am the new hero of the family. :-)
Lightfoot 01-14-2013 12:52 PM
(we won't tell)
Joe is da' man. :thumbsup:
jagans 01-14-2013 02:13 PM
Ill be GoTaHell. Joe, I would have never thought that could solve the problem.
Just goes to show ya. Ya larn sumpin ever dey. evn if it dont make any dang cents
:thumbsup:.
gusherb94 01-14-2013 05:56 PM
Does your toilet have a ballcock? (rod with float ball on the end) or something else such as a Fluidmaster 400A. I might suggest replacing your fill valve with a Korky Quietfill.
I've seen this happen before with old worn out ballcocks and high water pressure, the diaphragm inside will make a moaning sound during refill.
Click Plastics 01-15-2013 05:36 AM
sounds like the ballcock may need replacing
aj_chicago 03-25-2017 12:36 PM
Re: Whining toilet.
This fixed my "singing" valve. I believe it was actually high pitched whining at the shutoff valve. Just cranked it closed a few turns and no more whining. :thumbsup:
