Old 10-19-2012, 03:35 PM   #1
211
where to vent pressure relief valve if no access to outside
When we bought this house the pressure relief valve was not vented properly. It went down the side of the water heater into a hole in the floor and terminated into the crawl space. Inspector at the time didn't make too big of a deal about and merely said, "yeah, you'll want to fix that eventually".
I'm going to be putting in a new (energy star) water heater and would like to vent this pipe properly. Problem is, the water heater is kind of in the middle of the house inside a coat closet. There's no close access to the outside.
what other options do I have?
211 is offline   Reply With Quote
Old 10-19-2012, 03:38 PM   #2
joed's Avatar
It should go to a drain. It is water that will be coming out of it. There will also be specs as the length of pipe and number of bends allowed.
Do not PM with questions that can be asked in a forum. I will not respond.
Old 10-19-2012, 03:46 PM   #3
211
I thought that was not to code? I know... makes sense to drain water into the drain line... but I thought that was a no/no.
Also, I think the length needed to get to the ABS drain pipes may exceed the limit.
Old 10-19-2012, 08:01 PM   #4
call me E
TheEplumber's Avatar
Given the location of the heater, I'd still take the T&P into the crawl. Keep it in the joist area and pipe it out the rim joist. Once outside terminate it with a 90 pointed down. Keep it 6" above finished grade.
Codes very across the country so this may not be allowed in your area but we do it often.
If you're worried about length, you could always upsize to 1.5" pvc pipe.
Old 10-19-2012, 08:18 PM   #5
yep as eplumber said keep it in crawl space ..high and then run it outside...we do it here in my area of pa all the time as well...ben sr
Pressure Relief Valve Leaking new_DIY Plumbing 10 10-04-2012 11:24 PM
Relief valve on the water pressure tank leofff Plumbing 1 08-23-2012 04:27 PM
Help! Water Heater Pressure Relief Valve leaking mmoore58 Plumbing 4 01-02-2011 01:30 PM
Boiler blowing pressure relief valve alecmcmahon HVAC 1 10-18-2010 06:52 PM
Water Heater Pressure Relief Valve Leaking. merton Plumbing 2 03-29-2010 08:37 PM
