Old 01-11-2008, 06:18 PM   #1
Exclamation
Where is the toilet vent?!?!?
I was under the impression that all toilets needed a vent pipe. I am trying to tie a sink vent pipe into my toilet vent pipe, but cannot find the toilet vent pipe. I went under the house and found the drain pipe to the toilet. I pulled down some of the insulation, and it appeared that the drain connected directly to the bottom of the toilet because I believe I could see the bottom of the flange. The only problem is that the drain pipe connects directly to the horizontal main drain line and has no vertical vent. I drilled a 2" hole above the toilet to see if I was wrong and the drain pipe went up the wall behind the toilet, but there was no vent. I am sure that the drain pipe is under the toilet, because the toilet is directly across from the sink fixtures coming through the floor (I ripped out the vanity), and under the house the drain pipe is directly in the middle across from the fixtures going up through the floor. This house is in a subdivision built by Centex, and I'm sure it was built to code. All of the other faucets have AAV's on them, but I know that toilets have to have vents. Where is the toilet vent?!? I have attached pictures to give anyone who can help me an idea of what I'm talking about. The picture under the house shows the drain coming down through the floor and then going horizontal before going underground near the edge of the crawlspace. it does not connect to any vertical pipe that I can tell. How far can a toilet's wet vent go before it needs to connect to a vertical pipe? PLEASE HELP ME FIND THE TOILET VENT! Thank you very much for any help you may give me.
domgbrown is offline   Reply With Quote
Old 01-11-2008, 06:36 PM   #2
It's usually in the wall right behind the toilet. I don't think it can be any farther than 4' away from the toilet flange.
jerryh3 is offline   Reply With Quote
Old 01-11-2008, 06:47 PM   #3
It's not though, I drilled a 2" hole above the toilet to see, and there isn't anything behind the toilet.
Old 01-11-2008, 06:51 PM   #4
it is probly wet vented. where a line picks up the toilet then tub/shower then turns up for the lav and continues as the vent.
ranman469 is offline   Reply With Quote
Old 01-11-2008, 07:33 PM   #5
That's what I figured, but the drain for the toilet goes through the floor and does not connect to any vertical pipe underneath. It goes horizontal for a while, and then goes into the ground. It is also a lot thicker than all of the other pipes underneath and the other pipes connect into it while it is going horizontal, which leads me to believe that it is the main pipe that connects to the sewer. If this pipe connects directly to the toilet and does not connect to a vertical pipe, how can the toilet have a vent?
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
We are going to talk a little bit about the toilet flange here and this is where your toilet will sit. This is a 3 inch toilet flange and it ties down into our main 3 inch AVS sewer line and again we have that 1/8 inch fall per foot so that the solids... Read More »
We've all heard the frantic request from the bathroom to bring the toilet plunger before the toilet runs over. All of us will cope with a toilet malfunction at one time or another. Some repairs are best left to the experts, but many fixes are simple once... Read More »
We are going to talk a little bit about our waste lines and our vent lines right now. The waste line being when you turn the sink on and the water that falls into the sink, where does it go, well it goes right down into this pipe here, travels down the... Read More »
Anyone living with large, steaming hot radiators in their home will eventually think of replacing them with something smaller and cooler. A simple solution is to replace your radiator with a smaller, less sizable convector. Here are the steps to replace... Read More »
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Can I tie the sink vent into the toilet vent? domgbrown Plumbing 4 01-11-2008 06:28 PM
Yoke vent for water closet kenlog Plumbing 4 07-13-2007 07:34 PM
toilet vent problem? docholaday Plumbing 8 06-21-2007 06:05 PM
Bathroom Vent Not Vented to Outside / Would need to vent through flat roof House_Amuck HVAC 5 03-30-2007 10:57 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
