Old 03-07-2010, 09:56 PM   #1
hohadcr's Avatar
where to put main vent
i am adding 1.5 bath and a kitchen to 1 st floor of a 3plex. there is no existing venting.
the 2 toilets are about 7' away from the 4" main stack. and other drains are kinda surrounding the toilets.
i dont know if i should:
1. put the main vent ringt on top of main stack-- then i need to run auxilary venting for every drain;
2, or, put the main vent right where the toilet drains are -- then i only need to run a couple of aux venting, though the main vent is not on top of main stack(does that matter?)
what would you suggest?
thanks
hohadcr is offline   Reply With Quote
Old 03-08-2010, 08:22 PM   #2
hohadcr's Avatar
anyone can help pls?
Old 03-08-2010, 09:07 PM   #3
retired elect/hvac/plumb
plummen's Avatar
its depends on the layout and framing of your rooms
plummen is offline   Reply With Quote
Old 03-09-2010, 08:32 AM   #4
hohadcr's Avatar
right now, frame is up w/o drywall, so either way is possible.
There is no difference on the plumbing side?
AIR VENT SHINGLE VENT ll Docfletcher Roofing 8 06-04-2011 10:05 AM
Dual Main Breakers dcwestcott Electrical 3 02-23-2009 08:26 PM
Main Service Disconnects rwlawrence Electrical 5 11-04-2008 11:46 AM
main line vent BillyD Plumbing 3 03-15-2008 08:51 PM
Corrosion problem in vent stack. sgbotsford HVAC 2 12-01-2007 03:47 PM
