Where To Place Water Hammer Arrestor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2011, 11:56 AM   #1
Where to place water hammer arrestor?
We have a fairly new home, not quite a year old. In our master bath, we kept hearing a banging noise. After quite a bit of trial and error, we have isolated that the banging is located behind the shower wall when the washing machine turns the water off. It appears that placing a water hammer arrestor would be the simplest fix for this.
My question is where to place this? The washing machine is at one end of the house and the shower is at the other end. Do I place it closest to the washing machine or the shower? Or does it matter?
I have noticed this also happens occasionally when the toilet is flushed or the bathroom faucets are turned off, although not to nearly the extent as the washing machine.
The basement is un-finished right now, so getting to the pex should be easy enough.
scottieslg is offline   Reply With Quote
Old 01-05-2011, 12:41 PM   #2
Water hammer occurs where there are quick opening/closing valves, ie - washing machine. So it's best to install as close to the source as possible. If you install the attached whats in the attached pic, then it should be .
[IMG]file:///C:/DOCUME%7E1/Owner/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
VIPlumber is offline   Reply With Quote
Old 01-05-2011, 12:43 PM   #3
Rewards Points: 1,418
You will need the arrestors at the washing machine faucets and more arrestors at the shower faucets.
The toilet needs its own arrestor but you might get away with one arrestor for both toilet and shower, mounted just before the pipe branches off for toilet and shower.
Old 01-05-2011, 12:48 PM   #4
Thanks!
Is that a valve that has a water hammer arrestor already attached, or is it threaded on?
Old 01-05-2011, 01:28 PM   #5
It's already attached.
Old 01-05-2011, 01:43 PM   #6
They make some that attach with the hose connections.
http://www.castlewholesalers.com/SIO...-Arrester.html
Pistol Pete is offline   Reply With Quote
Cold water is warm - hot water leak under slab? Homerepairguy Plumbing 9 10-13-2010 09:17 PM
Water hammer problems Shyster & Shyst Plumbing 4 08-23-2010 11:46 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 09:42 AM
No water draining into sump pit aci4369 Plumbing 2 08-18-2009 01:17 PM
bad valve washing machine?? drdon51 Plumbing 6 06-29-2009 02:02 PM
