Where To Install Water Hammer Arresters ? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-21-2008, 08:48 AM   #1
Rewards Points: 1,062
Question
where to install water hammer arresters - CORRECTED ?
i initially said that the hammering was the most intense in the basement but, after seeing the post, he actually corrected me that it can be heard throughout the house, he just thought to install them there because it is the most convenient (exposed pipe).
while i have done many kinds of plumbing work (replumed successfully 80% of my house), i have never dealt with the issue of water hammer, hence the post.
my assumption was that water hammer is essentially a vibration which has to have its center where the amplitude is the greatest (like a string on a guitar) and my theory, which i was looking to (dis)confirm here was that the arresters should go approximately there.
so where the rubber meets the road is: where do we install these babies ???
Old 08-21-2008, 10:08 AM   #2
also, which arresters should we get, considering the intensity of the problem (heard in the whole house) ? i am thinking it may be worth to shell out a few more $$ and get decent ones from ferguson or some place rather than go with the nipple-looking ones from HD ...
Old 08-21-2008, 11:36 AM   #3
47_47's Avatar
Rewards Points: 62
Water hammer is usually caused by the closing of electric solenoid valves as found on washing machines, dishwashers... They are most effective when installed at the device.
If all the faucets hammer, your water pressure may be too high.
47_47 is offline   Reply With Quote
Old 08-21-2008, 11:58 AM   #4
Registered User
Termite's Avatar
Yes, fast-acting valves will usually be the culprit. The arresters should be placed right at the washing machine valves...Washing machines are often the biggest problem area.
Agreed, a pressure reduction may be in order if operation of the sinks and showers causes hammering.
Old 08-21-2008, 12:07 PM   #5
Question
okay then, we will slap a couple of nipple-looking arresters above the washer valves.
if the high pressure turns out to be the issue, should we get a bell-shaped pressure reducer at the entry point into the house like the one i happen to have before the pipe goes into my radiator boiler ?
Old 08-21-2008, 12:14 PM   #6
Most arrestors I have installed were located in the inlet and outlet piping at the water heater. It kept them accessable and easy to change if something happened to them. When I worked in Florida, the code required an 8" extension above each fixtures supply piping (except the kitchen sink) which was the same size as the supply piping and a cap on the end. This is what they considered hammer arrestors. I will say, Florida had some weird codes.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 08-21-2008, 02:23 PM   #7
47_47's Avatar
Rewards Points: 62
A question majakdragon, I could see the use of one on the outlet side of a water heater, but the inlet is usually teed off of the main branch. What purpose would one on the cold side serve?
Old 08-21-2008, 03:19 PM   #8
Since we did almost all one story homes, the water heater piping was the highest point on the waterlines. Having one on the cold water inlet also served the rest of the houses cold water feeds. We always fed the water heater first off of the main line. The reason the code called for these was to prevent water hammer caused by air in the lines. (not for quick shut-offs from appliances)
Old 08-21-2008, 07:23 PM   #9
Registered User
Termite's Avatar
In all my years, I've never seen anyone put hammer arrestors at a water heater. It just doesn't make any sense, no matter how the plumbing is configured. There is no potential for water hammer unless there is an abrupt interruption of flow...That does not happen at a water heater. Putting a hammer arrestor way upstream of a fast acting valve will not be as effective as locating it right by the valve.
Some old school guys will put air chamber (simply pipe stubs intended to be full of air) arrestors by shower valves and other fixtures. They inevitably fill with water in no time, and are a simple waste of time and pipe. The only way to go are the ones like Sioux Chief makes.
Old 08-21-2008, 11:14 PM   #10
thekctermite, as strange as you may think it is, it is code in Florida to put air chambers at each fixture except the kitchen sink. I have also seen water hammer with no "fast acting" valve being operated at the time. In many of the Forums I post in, the person asking about the noise states it happens with a bathroom sink or even a toilet when flushed. They always describe it as "the pipes in the wall are vibrating". Strange things happen in plumbing and I cannot explain them all. I just do what I can.
Old 08-23-2008, 12:33 PM   #11
Licensed Master Plumber
mstplumber's Avatar
Rewards Points: 150
Sioux Chief makes a wide variety of water hammer arrestors, many of which can be installed in a retro-fit application. They also have a pretty good FAQ about water hammer. Here's the link:
http://www.siouxchief.com/Frm_NS.cfm
Hope this helps.
Mstplumber
Check out my goofy video for my new toilet repair book.
mstplumber is offline   Reply With Quote
Electric Water Heater GTSRider Plumbing 31 12-07-2008 11:30 AM
How to install an expansion tank in my hot water furnace? DanBress HVAC 18 10-08-2008 03:57 PM
Water Stinks with recirculation pump carike Plumbing 6 08-05-2008 08:01 AM
DIY Install of Tankless Water Heater ManMythLegend Plumbing 7 12-21-2007 02:39 PM
Hot Water Cross Over rjordan392 Plumbing 3 09-11-2007 12:33 PM
