Where Does My Cast Iron Pipe Go? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-15-2012, 10:17 PM   #1
Trucon01's Avatar
Rewards Points: 510
Where does my cast iron pipe go?
Hi All,
I figured I would get a quicker reply here, so here goes.
I thought this pipe would continue straight for another 6 feet or so, but instead, after a few feet, it 90s straight down. Why would this be?
Townhouse built in 1974
Where does my cast iron pipe go?-photo-3.jpg   Where does my cast iron pipe go?-photo-4.jpg   Where does my cast iron pipe go?-photo-5.jpg
Basement Demo started Jan 2012: View my basement progression!!!
Bathroom demo started Feb 2013: View my bathroom progression!!!
Trucon01 is offline   Reply With Quote
Old 10-15-2012, 10:50 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Straight down to the city waste line.
sublime2 is offline   Reply With Quote
Old 10-15-2012, 10:50 PM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Possibly the building drain was laid directly on grade from the city main, and was brought up vertical under the house.
It's not unusual to have a deep pipe with a riser coming straight up off of it.
Is this causing you some kind of problem ?
Journeyman Plumber
Old 10-16-2012, 09:22 AM   #4
Trucon01's Avatar
Rewards Points: 510
No, no problem, just wasn't expecting it to go straight down. Since I am re-doing the plumbing for the full bath in that area, would it be OK to remove the cast iron pipe from one end of the elbow and replace with PVC? Or should I cut the cast iron pipe a foot or so away from the elbow and connect with a gasket? Which is the proper way since I'm not digging down any further?
Old 10-16-2012, 10:43 AM   #5
Doing it myself
Alan's Avatar
It wouldn't be a bad idea to eliminate the old fitting before covering it up with concrete again. Make sure the outside of the pipe is clean and smooth so you can connect it with a shielded no-hub coupling.
Journeyman Plumber
Old 10-16-2012, 11:28 AM   #6
Trucon01's Avatar
Rewards Points: 510
Thanks Alan,
So dig down more, expose the pipe coming up, remove the cast elbow and replace both the elbow and pipe before covering with concrete?
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Backpitched Cast Iron Pipe in Basement....uggh.. apunaha23 Plumbing 5 02-02-2011 02:42 AM
Main House Drain/Through Wall Cast Iron Pipe Docfletcher Plumbing 3 03-02-2010 08:41 PM
Leak in Cast Iron? Pipe under toilet... terrapin88 Plumbing 11 11-19-2009 06:54 PM
Rust Spot on Water Pipe (Cast Iron or Black Iron maybe?) markmaclean80 Plumbing 6 08-22-2007 09:20 PM
