Where Does This Hose Go - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-18-2013, 10:04 PM   #1
Rewards Points: 874
Where does this hose go
Should it be in the tube or out? Is is the hose that water comes out of to fill the tank. Thanks.
Mstrlucky74 is offline   Reply With Quote
Old 10-18-2013, 10:13 PM   #2
Rewards Points: 144
In the over flow pipe with a proper clip to attach it in the proper position. Fill tube should be positioned above the fill line. You can get a complete fluild master kit and replace all that for less than 20 dollars if needed. Or you can buy one of those clips for about 50 cents for a quick fix and your back in business.
jmon is offline   Reply With Quote
Old 10-18-2013, 10:47 PM   #3
Rewards Points: 6,652
Or just find a Paperclip jmon, create your own clip for nothing, and fix it with a little American ingenuity.
The Following User Says Thank You to gregzoll For This Useful Post:
jmon (10-19-2013)
Old 10-19-2013, 08:33 AM   #4
Master Plumber
Benplumbing's Avatar
Looking at your picture looks like there's a cleaning tablet in the tank. Remove the tablet and stop putting cleaning products like that in your tank it will destroy the innards. Unless you want toilet repair to be your new hobby
Benplumbing is offline   Reply With Quote
The Following User Says Thank You to Benplumbing For This Useful Post:
raylo32 (10-19-2013)
Old 10-19-2013, 09:47 AM   #5
Bill Kearney
Rewards Points: 1,174
+1. The chemicals in most of them are pretty rough on the flapper and seals. The rot out a lot sooner than necessary. That and they're not all that great for sewage systems in general.
wkearney99 is offline   Reply With Quote
Old 10-19-2013, 02:44 PM   #6
The only ones that I have found to be any good, are the Clorox tablets, that do not eat the Rubber or plastic parts.
Old 10-19-2013, 03:36 PM   #7
Bill Kearney
If it's got bleach in it then it WILL eat the parts. Maybe not as soon as others but the chemicals in it will definitely degrade the stuff. The plasticizers in the components just won't hold up when exposed to those kinds of solvents.
If anything, the kind that clip into the bowl area are "less worse" in that they won't be causing all the rubber bits in the tank to sit there soaking in it. They're still really not good for the sewage systems though.
The Following User Says Thank You to wkearney99 For This Useful Post:
Benplumbing (10-19-2013)
Old 10-21-2013, 11:23 PM   #8
Master Plumber
Javiles's Avatar
Rewards Points: 984
I thought it was vanilla chocolate mocha.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
The Following User Says Thank You to Javiles For This Useful Post:
Benplumbing (10-22-2013)
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 10:20 AM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 01:51 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 01:18 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 01:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
