Where Does Heater Drip Pan Drain Go In Condo? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-27-2011, 02:02 PM   #1
Where does Heater Drip Pan Drain Go in Condo?
I'm trying to figure out where a drainage pipe is running in my NJ condo. I live in a condo with a first and second floor. My hot water heater is located on the second floor. The drip pan connects to vertical PVC, which then runs down my closet wall on my first floor and into the concrete floor. My question is, where does this drain go? I believe there are 3 possibilities:
1. It eventually connects to an indirect waste receptor in the foundation.
2. The pipe isn't connected to the plumbing and drains directly into the gravel under the foundation.
3. The pipe isn't connected to the plumbing and is routed away from the foundation underground.
Does anyone have insight into how this is set up? Thanks in advance!
mattk is offline   Reply With Quote
Old 12-27-2011, 02:15 PM   #2
It should be connected to the storm drainage system.
VIPlumber is offline   Reply With Quote
Old 12-27-2011, 02:27 PM   #3
MarginallyQualified
Rewards Points: 2,464
Originally Posted by mattk View Post
I'm trying to figure out where a drainage pipe is running in my NJ condo. Does anyone have insight into how this is set up? Thanks in advance!
This one:
3. The pipe isn't connected to the plumbing and is routed away...
(somehow or other, hopefully)
Can the floor drain mandate be skipped if I switch to a tankless heater brokenhammer Plumbing 1 08-08-2011 11:26 PM
How do I drain my water heater? HVAC_NW Plumbing 10 11-10-2010 03:15 PM
Hot Water Heater Drain Valve Mitch125 Plumbing 4 09-28-2010 12:07 PM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
Wierd Floor Drain "Backup" rawkintrevo Plumbing 9 06-04-2008 07:10 PM
