Where Do I Find The Most DURABLE Outdoor Showerhead Kit Under $150. - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-12-2012, 04:21 AM   #1
Where do I find the most DURABLE outdoor showerhead kit under $150.
My husband loved the outdoor shower we used in the Outer Banks. I would like to surprise him by installing one at our home. I selected a spot near the rear of our home within 10 feet of our basement hot water tank, W&D, and outside hose spigot. We don't need anything fancy, just a shower head and knobs, which I hope to surround with cedar tongue and groove enclosure, over 6" ground of pebbles covered by decking floor. Suggestions to keep this simple and as inexpensive as possible?
suegee1950 is offline   Reply With Quote
Old 05-12-2012, 05:46 AM   #2
MarginallyQualified
Rewards Points: 2,464
How about wayyyyyyy under $150?
Then even if it proves un-durable (it won't) you can afford to replace it.
Look for a "jet" sprayer like this one. Works great.
About $15 at Ace in March when I last bought one.
Old 05-12-2012, 05:55 AM   #3
DIY staff
Rewards Points: 7,174
For the mixer valve--I suggest a Moen single handle unit--the guts are rugged and the base model is less than $100--
I suggest you use a tub mixer---it will be handy to have a spout down low---often you will want to wash your feet only,before entering the house.
Use PEX piping if it is allowed in your area--PEX has the best freeze/thaw rating of the commonly available piping.
Old 05-12-2012, 09:48 AM   #4
Rewards Points: 13,732
One key thing is where do you live? Plumbing on an outside wall in a freeze zone is not a good thing.
A valve that I have used in the past for an outside shower is this one.
http://images.search.yahoo.com/searc...+rack+pull+out
I used the vertical one so I could run the pluming in a wall and out through a wall stud. I used a jumbo siding block on the outside wall then ran the siding around it.
Old 05-12-2012, 09:53 AM   #5
USA location
I live in Maryland, so we would have to drain the water out of pipes and turn off supply each winter
Old 05-12-2012, 10:34 AM   #6
If you do as I suggest it's as simple as disconnecting the hose from the faucet.
Where to find a contractor? sgt_utz Building & Construction 2 09-28-2011 06:15 AM
Can't find good laminate comparison anywhere cpsilo1 Flooring 3 03-20-2011 04:49 PM
