Old 01-09-2012, 09:44 AM   #1
Where Can I find a 3.5 Inch Flush Valve?
I need to replace the 3.5 inch flush valve on my American Standard toilet. Noone seems to carry this larger size flush valve. At this point, I don't care if its the flapper or tower design, i just need a 3.5 inch flush valve.
Does anyone else besides American Standard use this larger size?
limitdiy is offline   Reply With Quote
Old 01-09-2012, 09:51 AM   #2
What part of it is 3-1/2"?
Ive never heard of a flush valve rated by size.
Old 01-09-2012, 08:54 PM   #3
most flushvalves are all the same size as far as I know..flappers differ..did you measure your flushvalve and another standard one????
The Following User Says Thank You to ben's plumbing For This Useful Post:
plummen (01-09-2012)
Old 01-09-2012, 09:02 PM   #4
have a look here: http://www.plumbingsupply.com/toilet-flush-valves.html
epson is offline   Reply With Quote
Old 01-09-2012, 09:23 PM   #5
hummer4x4guy's Avatar
IF you cant find the proper flush valve... Eljer does make a 4" flush valve toilet and it is awesome! Tho yes you would have to get a whole new toilet. Thats the only help I have to offer. And my help is worth what you paid for it. :-)
Joel
hummer4x4guy is offline   Reply With Quote
Old 01-09-2012, 11:52 PM   #6
retired elect/hvac/plumb
plummen's Avatar
When you say flush valve this is first thing that comes to my mind!
plummen is offline   Reply With Quote
Old 01-10-2012, 12:40 AM   #7
Is this what you need? The green/blue edged flush valve?
Where Can I find a 3.5 Inch Flush Valve?-am-stand-flapper-1-.jpg   Where Can I find a 3.5 Inch Flush Valve?-am-stand-flapper.jpg
hammerlane is offline   Reply With Quote
Old 01-10-2012, 06:45 PM   #8
could you get it alittle closer I can't see it:laughin g:
Old 01-10-2012, 10:17 PM   #9
that is exactly what I needed. Noone had the bigger 3.5 inch flush valve. Finally there was a store, not too far away from me that was an American Standard dealer, and they had that part.
When I say 3.5 inch , I mean the diameter of the hole on the bottom of the tank. Normally, its around 3inches or less, i think. But this American Standard champion toilet I have, it was apparently bigger.
that dang flush valve cost me 40 dollars.
Old 01-10-2012, 10:30 PM   #10
I had to buy 4, for a customer that were really old Kohler brand and he paid well over $300.00 each for them.
I tryed to tell him he could buy a whole toilet for less.
Old 01-10-2012, 10:37 PM   #11
that is exactly what I needed.....
I needed the same. The blue seal kept leaking. My tank part # was 4260.
After looking online I saw a lot of people had trouble with these Champion 4 flush valves from American Standard. From what I understood, Am Standard knew the original blue seals were faulty. They would "bubble up" or "blister" and cause the leaking.
I called American Standard and without even asking how old the toilet was they sent me a free seal.
Anyway here is where I obtained my info: read post #10
http://www.doityourself.com/forum/to...-better.html#b
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 01:20 PM
Fix-a-loo TOILET outlet valve not closing/shutting toiletproblem Plumbing 4 08-21-2011 04:25 AM
Flush Valve Seat sticking to Tank Ball Leah Frances Plumbing 2 05-23-2011 07:53 AM
unable to stop leaky kitchen faucet w/ new valve diy888 Plumbing 0 02-27-2011 09:45 AM
Installing toilet on a concrete floor, Can't find a flange that will fit flush to the floor Pete R. Plumbing 1 10-09-2010 06:33 PM
