Where To Buy 3"+ Solid PVC Pressure Rated SCH40 Pipe? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-10-2012, 03:40 PM   #1
Rewards Points: 45
Where to buy 3"+ solid PVC pressure rated SCH40 pipe?
Seems that all the Depos and Lowes in the Raleigh, NC area do not carry solid core sch40 pvc pipe in 3" or larger...where can i find this in the area?
This will actually be used to store vacuum for a vacuum press build and I need to ensure I get the right material...
THX
kooshball is offline   Reply With Quote
Old 11-10-2012, 03:46 PM   #2
Rewards Points: 13,446
Your going to need sch 80 not 40.
Any commercial plumbing supply should have it.
PVC gas vent rated pipe Gordlem HVAC 5 04-22-2012 06:54 PM
ABS drain pipe leaks under pressure test abracaboom Plumbing 12 01-24-2012 07:27 PM
replace a pice of pipe, how to properly shut off/vent pressure langless28 HVAC 1 01-11-2012 11:56 AM
replacing cast iron pipe davemarz Plumbing 1 05-20-2011 09:16 PM
Intermittent Low Water Pressure Fox Plumbing 4 03-02-2010 06:04 AM
