Where Is The Best Buy For An Electric Snake? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-05-2009, 03:21 AM   #1
Question
Where is the best buy for an electric snake?
To snake out toilet bowls, 3 1/2 - 4" drain.
Peter H is offline   Reply With Quote
Old 01-05-2009, 12:17 PM   #2
I would not advise using a snake for toilet bowls. they tend to scratch the surface. The proper tool for this is a Closet Auger. Snaking 3 and 4" lines requires at least a 3/4" cable with changable heads. They have "arrow type" and cutter heads. Not cheap for a good one. If you don't do this for a living, rental is the best answer. Some units come with the cable wrapped around a drum and others have 8' lengths of cable that are attached as needed. For regular house drains (sinks and such) Ridgid makes a powered unit with a foot pedal and 30' of cable. About $130 at Home Depot.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Old 01-05-2009, 04:39 PM   #3
Still need to be careful you don't scratch the bowl but much safer then trying a snake . I prefer my handy plunger first though.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
How to use a snake to clear a drain? Nestor_Kelebay Plumbing 11 12-09-2008 04:45 PM
Connecting electric motor to swtich and marine battery Lawnplugger Electrical 5 09-13-2008 01:11 PM
Electric Heat pump in New England? jzinckgra HVAC 7 05-22-2008 02:02 PM
Electric Line Under Ground Crazy Legs Electrical 9 04-15-2008 10:07 PM
Electric tankless hot water heater former33t Plumbing 2 02-28-2008 11:40 AM
