When A Wax Seal Should Be Replaced. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 10:27 AM   #1
When a wax seal should be replaced.
Wax seal on our toilet leaked because of a blocked sewer line. Blocked line has since been fixed. Should the wax seal be replaced now that it has leaked once?
Smitti is offline   Reply With Quote
Old 02-19-2012, 10:30 AM   #2
Rewards Points: 13,450
Any time a seal leaks it's time to change it. It's about a $3.00 piece and DIY 101.
Smitti (02-19-2012)
Old 02-19-2012, 01:09 PM   #3
(the original)
Rewards Points: 756
And, just an FYI, the blockage didn't cause the leak, it just allowed water to stand at the connection and expose the leak.
Spend $5 and get the kit that includes closet bolts, too, unless they still look new.
ratherbefishin' is offline   Reply With Quote
The Following User Says Thank You to ratherbefishin' For This Useful Post:
Smitti (02-19-2012)
Anchor Seal Leaching on IPE rocketdoctor Building & Construction 5 09-07-2010 09:46 AM
Ready Seal Deck Stain jbtn9 Flooring 2 08-27-2010 11:52 PM
How should I seal Louver Vents no Longer being used? earthad1 Building & Construction 10 02-18-2009 08:32 AM
Can't seal tub spout against new tub surround darsunt Plumbing 1 01-05-2009 01:50 AM
to seal or not to seal, this is the question dvarga Flooring 3 08-07-2005 08:21 AM
