Old 10-24-2008, 03:55 PM   #1
Default When soldering copper, what causes the solder not to "suck in"?
I've replaced all the copper pipes in my house (in my area copper pipe only lasts 40 years), replacing it with new rigid copper pipe. Everytime I heated up a joint and applied the solder it would get "sucked in". I just did one that didn't suck in the solder which surprised me, the solder just seemed to melt around the fitting and stayed at the surface. What causes that?
My technique is:
Sand the fitting & the pipe
flux both
Slide them into each other and give a slight twist
Heat the middle of the fitting as, solder flows to the heat
Keep the flame applied until the flame turns green on the opposite side
Apply solder, and it "sucks" right in.
If it's 1/2" pipe apply 1/2" of solder. If it's 1" pipe I usually apply 1" solder
After doing all the steps above like I usually do, the solder in this case melted and flow around the outside of the fitting but didn't suck in. Now, it does appear to have fully covered the junction (even though it didn't suck in) but what causes that, and do you think my joint is junk?
Piedmont is offline   Reply With Quote
Old 10-24-2008, 04:00 PM   #2
011000100110111101101111
DangerMouse's Avatar
i'd start by pulling the joint apart to be sure no water had seeped into the joint. that would cause what you describe.
DM
Old 10-24-2008, 04:06 PM   #3
Hmm... this is new pipe & new fittings, to a new loop I haven't connected yet to water, and I've kept the pipe in the room with my wood stove (without a steamer) so, it should be very dry. Is there anything else besides water that causes that?
Old 10-24-2008, 04:07 PM   #4
DIY'r
ScottR's Avatar
x2.
If no water, then maybe something else got on it after you sanded, oil or somesuch? Maybe in that one case, the pipe and fitting didn't get hot enough..
Sounds like you're doing things right, though.
My 2c is that if you're ever unsure of a joint, pull it apart and redo it. Even it it turned out to be good, it's better to take the 5 min now than forever wondering when it will leak.
ScottR is offline   Reply With Quote
Old 10-24-2008, 04:09 PM   #5
hmmmm..... open a valve in the line to let air in? maybe pressure is doing it?
DM
Old 10-24-2008, 04:18 PM   #6
RippySkippy's Avatar
I'd pull it apart and re-do it. DM may have something if it's a closed loop the increasing air pressure could force the solder out. Short of that it sounds like you have good technique. I guess I've never watched the flame on "the other" side...but be careful that you don't over heat the copper.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 10-24-2008, 04:25 PM   #7
agreed, it sounds like you're doing it all by the book..... hey rippy
DM
Old 10-24-2008, 05:29 PM   #8
Hot Wire
KE2KB's Avatar
If nothing else works, I would use a different fitting and / or piece of pipe. Maybe some invisible defect in the pipe or the fitting interacting with the solder.
KE2KB is offline   Reply With Quote
Old 10-24-2008, 07:21 PM   #9
Custom Cabinet Maker
skymaster is offline   Reply With Quote
Old 10-24-2008, 07:30 PM   #10
cqdf? huh?
DM
Old 10-25-2008, 10:59 AM   #11
Try all the steps you took but be sure the inside of the female fitting is brushed or sanded and apply the flux immediately after sanding to exclude oxygen. Be sure there is no pressure, or water getting into the pipe. If there is water getting into the pipe stuff a piece of white bread into the source side. This will obsorbe water for a little while and is harmlessly flushed away upon use. I always continue to apply solder after heat is removed and look for no gaps between the components. good luck
Mike2756 is offline   Reply With Quote
More On This Topic
How to Fit Copper Pipes
How to Fit Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and back with you on copper piping. Here are he three pieces that we are going to put together. I've got the flux and we've got our torch ready to go, dry fitted them. We know that everything is fitted... Read More »
Hi, my name is Ken D. Orlich on behalf of Expert Village. Okay, in this segment, I'm going to show another method of removing solder. Its not one I particularly like, but some people seem to find enjoyment out of it. It's using something called Chemwick... Read More »
Hey everybody Don Golden with Expert Village and we're moving on with our copper piping. I'm going to show you now what you need to join these in everlasting matrimony. What we are going to do is we are going to use what is called flux paste. This is a... Read More »
How to Sweat Copper Pipes
How to Sweat Copper Pipes by Expert Village
Hey everybody Don Golden with Expert Village and we are working on our pipes. We have got pretty much everything ready to go. We have got our flux on. We have got our torch ready and our solder at hand and I am just going to fit these now and the flux... Read More »
How to Dry Fit Copper Pipes
How to Dry Fit Copper Pipes by Expert Village
Hey everybody Don Golden here with Expert Village. We are talking about copper piping and copper fitting. We have prepped these two little demo pieces and the 90 degree union that I am going to show you how to sweat shortly but I got a little ahead of... Read More »
Copper Soldering Problem Eric_ht Plumbing 4 09-08-2008 10:17 PM
Flexible copper or Rigid Copper for solar? Piedmont HVAC 5 06-11-2008 11:47 PM
Flexible Copper or Rigid Copper? Piedmont Plumbing 1 06-10-2008 03:40 PM
Debate - Pex vs Copper sandy2982 Plumbing 13 04-11-2008 12:47 AM
Soldering copper pipe gail synsteby Plumbing 14 03-22-2008 02:08 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
