When To Replace Toilet: Rule Of Thumb? - Plumbing - DIY Home Improvement | DIYChatroom
Old 12-30-2009, 05:55 PM   #1
When to Replace Toilet: Rule of Thumb?
I have 3...likely the original toilets which were in the house when built in 1990. The powder room toilet flushes sluggishly...just circles round and round then empties slowly.
Is there a shelf-life for toilets...say replace them every X years? Or is this something I should try to clear first. I used a plunger...wasn't much help.
Thanks in advance!!
CP
coolptnr is offline   Reply With Quote
Old 12-30-2009, 06:19 PM   #2
when you are out shopping for anything but a toilet is the idea time, but you are right, first find out why its not flushing correctly. Outside of saving water, or the china is broken, no need to change them, unless someone before you installed one of those $99 complete kits and its giving you fits.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 12-30-2009, 06:53 PM   #3
firehawkmph's Avatar
Rewards Points: 1,826
When you get ahold of a good one, you pass it on to your kids.....
Mike Hawkins
http://www.tvacres.com/props_toilets_ferguson.htm
firehawkmph is offline   Reply With Quote
Old 12-30-2009, 07:13 PM   #4
Thanks Dude...appreciate the info.
CP
Old 12-30-2009, 07:15 PM   #5
replace when crap runs uphill
Old 12-30-2009, 07:16 PM   #6
LOL!!!...thanks firehawk!!
CP
Old 12-30-2009, 07:18 PM   #7
I've only replaced 5g units with 1.6g water savers
If they keep clogging & you have ruled out a clogged pipe (not in the toilet) then time for a better toilet
Old 12-30-2009, 10:36 PM   #8
Thanks to all for the input. Just got back from the neighborhood big box store and bought an auger. Will put this baby to work in the morning...hopefully this will clear it.
Old 12-31-2009, 08:36 AM   #9
You may not find the problem in the toilet trap or bowl. 20 years is a long time to the parts in the tank. Many times, an couple adjustments to the moving parts will solve the problem. make sure the chain/strap that lifts the flapper is set to allow the flapper to "just" seal. This will insure the flapper is being opened all the way to allow for a proper flush. Flappers can go bad or start binding and not opening all the way. The holes under the bowl rim can also get clogged with deposits. Check these with a mirror and see if they are all open.
If you have never made a mistake, you haven't done much.
majakdragon is offline   Reply With Quote
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 08:52 PM
Replace a 10" rough in toilet with a 12" rough in Opie46 Plumbing 3 05-16-2009 12:27 PM
Toilet jpark Plumbing 18 01-05-2009 08:12 AM
Is it time to replace the toilet? Deahmx Plumbing 8 08-12-2008 02:11 PM
toilet leak after replace new wax ring druffino Plumbing 4 07-17-2008 11:31 PM
