When Installing New Tub Drain Is It Supposed To Be Flush With The Floor? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-25-2013, 10:47 PM   #16
Master Plumber
Javiles's Avatar
Rewards Points: 994
I hate tube resets, back in 79 i had to remove and reset 125 tubs in a buiding that went from rentals to condos, all cast iron tubs Kohlers, brass drains new traps cast iron leaded in. Today i wont touch a tub for under a grand. and that's for a simple set, good luck poster just make sure you check and double check for leaks open and closed drain tests.
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 03-31-2013, 02:44 PM   #17
Rewards Points: 150
I think I should have used one of these, I might try one for my next bath.
https://www.buyeagle.biz/flex-916
Arsinek is offline   Reply With Quote
Basement floor drain backup mimi123456 Plumbing 6 09-28-2012 11:02 AM
Laminate or vinyl on a concrete basement floor? pjpjpjpj Flooring 36 09-03-2012 01:37 PM
waterproof around floor drain orhan Plumbing 7 11-02-2010 07:13 PM
Floor Drain, require constant drip? acerunner Plumbing 2 10-19-2010 04:11 PM
Carpet in the basement Packer Backer Flooring 16 11-03-2008 11:19 PM
