Old 07-13-2009, 10:55 PM   #16
Water Well Driller
When Connecting Threaded PVC Connectors
Originally Posted by handy man88 View Post
Chamfering the edges of the PVC pipe is almost a must do. If not, then fittings kind of push back when you try to insert them.
Agreed. Because I fell into the plumbing end of things, I had to learn this lesson the hard way
piercekiltoff is offline   Reply With Quote
Opinions of Ideal push-in wire connectors Bigplanz Electrical 59 09-07-2012 05:02 AM
Better way of connecting cable loop to roller chain? deleyd General Discussion 1 06-30-2009 11:52 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
Connecting threaded pipes on pool fittings NJ guy Plumbing 1 05-05-2008 09:21 PM
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 05:33 AM
