When Connecting Threaded PVC Connectors - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-11-2009, 06:22 PM   #1
Rewards Points: 1,088
Do you use joint compound or Teflon tape?
handy man88 is offline   Reply With Quote
Old 07-11-2009, 06:27 PM   #2
GC/Master Plumber/Mech
Rewards Points: 560
Teflon
Old 07-11-2009, 08:06 PM   #3
Originally Posted by Plumber101 View Post
Teflon
Any reason you prefer that?
My application is for a threaded fitting that goes into the condensation pan in the air handler.
How many wraps?
Old 07-11-2009, 09:08 PM   #4
Household Handyman
Rewards Points: 1,408
There's a lot of "each to his/her own" in plumbing, and I look at the situation to determine which to use. In your case, which you did not state in your first post, you are not dealing with pressure in a condensate drain, therefore I would use compound, specifically teflon compound. I only carry with me the teflon compound/dope and teflon tape, and as I stated, depending on the application which one I will use. PVC carrying any pressure, I use teflon tape, no pressure, teflon dope. Any screw joint on metal piping, I use teflon dope period. That's just me after 38 years of Industrial Maintenance and Home Repair. Thanks, David
Old 07-11-2009, 10:41 PM   #5
Thanks for passing along your expertise. I'm lucky I have some teflon joint compound in my tool box.
Off topic, I do recall that a certain type of joint compound is not compatible with pvc pipes, but I don't think it affects me.
Old 07-11-2009, 10:47 PM   #6
Do you find it interesting that you seldom see the purple primer used in joints for condensate lines?
I see the purple tint in drain lines and in the sump discharge, but never in condensate lines.
Old 07-11-2009, 10:59 PM   #7
Rewards Points: 560
Just use teflon less mess. The only time I use teflon dope is when I'm working on a water well. Every thing else I use rector seal.
Colored primer is used primarly for inspection so that the codes official knows that the pipe was cleaned. Also it is a requirement of code.
Old 07-11-2009, 11:24 PM   #8
And not a requirement for condensate lines?
Old 07-11-2009, 11:31 PM   #9
Rewards Points: 560
I can't remember without looking at code but I don't prime condensating line and I have never had an inspector fail me.
Old 07-11-2009, 11:45 PM   #10
What "benefit" is lost by not priming? I've read that besides being a visual indicator, the primer actually softens the pvc and reacts with the cement to cure faster.
I've never made connections without primer. How much longer to cure without primer, or does the twisting action itself generate the onset of the cure?
Some say that the primer is the cleaner, but Oatey also sells a separate cleaning solvent.
Old 07-12-2009, 12:07 AM   #11
Rewards Points: 560
I always clean, prime and glue on pressured lines, on waste lines I prime and glue. What is lost is that if the two surfaces do not fully connect through a solvent reaction because of impurities then there could be a failure or leak.
Nothing sucks more than cutting out pipe in the basement that is connected to two more floor above.
There is a product called Rain and Shine that can be use with wet pipe and it seems to work. I glue and twist all pipe and if I am making a repair I will let it set up for five mins. Always read the glue instructions on the can for specifict times.
I carry an all purpose glue, CPVC glue, can of Rain and Shine, cleaner and primer on the truck
Old 07-12-2009, 12:40 AM   #12
So you would use the purple primer on a condensate line?
Old 07-12-2009, 09:39 PM   #13
Water Well Driller
According to the manufacturers, primer is a softening agent that jump starts the process that the glue also does. Twisting just makes sure the glue is evenly spread throughout the joint. Because I'm always working near the pressure source, and secondly for inspection reasons, I prime everything, then use rain & shine glue, plus I chamfer edges and physically clean the joint prior to the prime/glue, twist-connection. Priming also allows for a shorter curing period.
Teflon tape is what I use for surface threaded connections - it's cleaner than dope. Also, I never use female threaded PVC fittings, I switch to brass/bronze/stainless if I need a female thread.
In the well, I dope the joints - also, I use schedule 120 PVC and tapered stainless steel couplers in the well.
piercekiltoff is offline   Reply With Quote
Old 07-12-2009, 11:52 PM   #14
HVAC / Plumbing
for condensate drain . I use silicone on the threads
kenmac is offline   Reply With Quote
Old 07-13-2009, 04:53 PM   #15
Chamfering the edges of the PVC pipe is almost a must do. If not, then fittings kind of push back when you try to insert them.
Opinions of Ideal push-in wire connectors Bigplanz Electrical 62 07-03-2014 11:29 PM
Better way of connecting cable loop to roller chain? deleyd General DIY Discussions 1 06-30-2009 11:52 PM
Very Small leak at Shower Valve on Cold Water Side, Threaded. Tighten it more or ? twilightcall Plumbing 3 08-25-2008 09:19 AM
Connecting threaded pipes on pool fittings NJ guy Plumbing 1 05-05-2008 09:21 PM
Twin Impeller Shower Pump Connectors snowman23 Plumbing 1 11-11-2007 05:33 AM
