When To Adjust PSI Of Expansion Tank - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-20-2012, 10:59 PM   #1
Rewards Points: 45
When to adjust PSI of expansion tank
I recently installed a pressure reducing valve, and a 4.5 gallon Watts expansion tank. The tank came preset at 20 psi, and I'm confused as to why or if the 20 psi should be increased (the instructions are rather vague). According to the Watts sizing calculator my system needs a tank larger than 3.62 gallons so I would assume that 20 psi is okay? My static pressure is 55 psi, two 50 gallon hot water heaters @ 135*. Any help is greatly appreciated.
Austin83 is offline   Reply With Quote
Old 11-21-2012, 11:07 AM   #2
Special User
Rewards Points: 1,230
The pressure should be set two PSI below the expected system pressure, so, 53PSI.
Running with pressure too low overstretches the rubber bladder. It will fail prematurely and then you have a 0.00 gallon expansion tank.
tylernt is offline   Reply With Quote
Old 11-21-2012, 07:48 PM   #3
Rewards Points: 582
set tank pressure to equal incomming pressure....if incomming is 55 set tank to 55..ben sr
Old 11-22-2012, 08:54 PM   #4
Rewards Points: 45
Thanks! Got it adjusted.
Two plumbing questions: Water heater drain and expansion tank. TexasPenguin Plumbing 10 10-30-2012 01:35 PM
Septic tank missing T and badly angled main line? denemante Plumbing 3 11-22-2011 09:29 AM
Old expansion tank leaking Ultrarunner2017 HVAC 7 11-16-2011 06:40 AM
Is a Hot Water Expansion Tank required Needagameplan Plumbing 9 04-27-2010 03:09 PM
Pressure relief leaking and expansion tank full themow HVAC 1 11-25-2009 04:49 PM
