Whats This Pipe For? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-06-2012, 12:30 AM   #1
heinlein0311's Avatar
Rewards Points: 81
Whats this pipe for?
We had our house built last year and there's a PVC pipe extruding from the ground just above where the main drain comes out of the house to the septic tank. We also used "form a footer" and I believe that ties into the main line as well. But what is that pipe outside for? It's located on the bottom right of the pic. There's also "future plumbing" or drain stubs located in the basement just on the other side of the wall of the extruding pipe. Would it by chance have anything to do with that?
heinlein0311 is offline   Reply With Quote
Old 08-06-2012, 06:06 AM   #2
DIY staff
Rewards Points: 7,174
Most likely, that is a clean out---open it and see---if it is---you can cut it down to a more appealing height and install a new female fitting and cap.
Old 08-06-2012, 11:01 AM   #3
Rewards Points: 3,130
We have five of those things sticking up like that. Yours is probably a cleanout (we have one too), but where we live, inspection points are required at the distribution box and at the end of each lateral in the drain field. A seriously stupid requirement IMO.
Old 08-06-2012, 11:46 AM   #4
Rewards Points: 81
Wow that would be an eye sore to have all those sticking up through the yard. Thanks for the info!
Old 08-06-2012, 04:51 PM   #5
Rewards Points: 582
could be main house trap .
Old 08-06-2012, 11:18 PM   #6
Up here we're required to have a main line cleanout within 1m (3') of it's entry point into the house. It is a little high and could be easily adjusted as Mike suggests.
VIPlumber is offline   Reply With Quote
Old 08-07-2012, 08:21 AM   #7
Rewards Points: 81
Thanks for the advice. That must be what it is. Adjusting the size shouldn't be an issue, hide it with some landscaping and we'll never know it existed.
The Following User Says Thank You to heinlein0311 For This Useful Post:
oh'mike (08-07-2012)
Old 08-07-2012, 12:25 PM   #8
Owner
LateralConcepts's Avatar
It's a cleanout for the septic line. You should not have footer drains connected to the main septic line. Additionally, I would be a bit concerned with the way the cleanout appears to be leaning backwards toward the house. Settling may have occurred causing a negative grade or possible break in the line. Maybe it's just the angle of the picture. Hard to tell.
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
Best way to join Poly pipe, for a water pipe repair. carl1864 Plumbing 10 11-03-2014 12:31 PM
Working with B-Vent pipe for WH vent BobN HVAC 16 01-25-2012 11:58 PM
Qs about the 1/2"dia brass pipe we bought smoochas Plumbing 10 02-21-2011 09:23 AM
What’s the best way to remove pipe from T Jaylyn Plumbing 2 02-03-2011 01:05 AM
