What's This Length Of CPVC For? - Plumbing - DIY Home Improvement | DIYChatroom
Old 10-05-2012, 02:52 PM   #16
joed's Avatar
Rewards Points: 11,518
There is no way for the air to get out. It will be trapped. To see the principle take a pop bottle. Turn it with the open end down and push it into a pail of water. The water will rise slightly inside the bottle but since the air can't get out it will be trapped.
Old 10-05-2012, 03:26 PM   #17
Perhaps you have above-normal water pressure for your house which might explain why previous owner installed these water hammer resistors.
It really should not cost you a lot in terms of money and time to restore it's original setup; otherwise, if you decide to skip it, you may end up opening this wall again (or some other walls) to deal with water hammer effects.
Here is a link to wiki article which explains the what and how questions (http://en.wikipedia.org/wiki/Water_hammer)
Good luck
allthumbsdiy is offline   Reply With Quote
The Following User Says Thank You to allthumbsdiy For This Useful Post:
DangerMouse (10-05-2012)
Old 10-05-2012, 03:51 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 792
Originally Posted by TheEplumber View Post
Yes, over a long period of time the air will mix into water though. Then if you drain the water down it will pocket air again
Sent from my iPhone using DIY Forum
Because the air is lighter than water....it will stay up in the pipe.
It should work as intended....as long as there are no leaks.....you could have a really really small leak....enough for air to go out...but not water....so eventually, the air gets pushed out and you end up with a tube full of water doing nothing for you.
ddawg16 is online now   Reply With Quote
Old 10-05-2012, 04:32 PM   #19
Rewards Points: 588
Ok so just buy a 3/4 to 1/2 inch T and be done with it? (Or I guess a 1/2" T with a 3/4 to 1/2" reducer bushing) Am I missing anything?
noone is offline   Reply With Quote
Old 10-05-2012, 04:40 PM   #20
I haven't dealt with CPVC but I would prefer to use a tee with 3/4" and 1/2" so that there is less chance for leaks (http://www.lowes.com/pd_133209-322-5...r|1&facetInfo=)
Help with running new CPVC water lines. Integraoligist Plumbing 0 03-05-2012 03:17 PM
Water Heater Connections (CPVC) Pittsville Plumbing 16 01-21-2012 09:02 AM
CPVC Installation Questions Pittsville Plumbing 24 01-30-2011 09:38 PM
Connecting Water Filter Housing to CPVC Pittsville Plumbing 7 01-20-2011 03:01 PM
Hardwood Length...preference? JDeFuria Flooring 3 03-10-2009 06:38 PM
