Whats The Best Way Laundry Sink Drain Issue - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-17-2014, 02:51 AM   #1
Rewards Points: 256
whats the best way laundry sink drain issue
I only have a kitchen sink and 2 bathroom sinks to use to wash hands etc . im about to remodel my kitchen and wont be using that sink anymore after its done , only for dishes . I want to put a utility sink in the basement laundry room for cleaning hands etc after getting dirty hands from yard work vehicle work .
problem is my main sewer line to the ceptic tank is about 4 feet high and a normal sink drainwould be 2-3 feet lower that that . is it ok to drain water into a catch basin then have a sump pump pump it up to the main sewer pipe maybe use a back flow stopper . maybe just pump it outside instead ?
oldrivers is offline   Reply With Quote
Old 03-17-2014, 06:29 AM   #2
DIY staff
Rewards Points: 7,174
For a 'remote' sink like that---the simplest and cheapest way to drain it is to use a pump box----this will lift the sewage up to your drain system----the units are easy enough to install---
Code calls for a hard piped vent for the box----that can be an issue----an AAV is not designed to work with a sump pump---
As a seldom used scrub sink----let your conscience be your guide as to code---just be aware that the thing will be looked at by an inspector when you sell the place--Mike---
Old 03-17-2014, 08:07 AM   #3
Rewards Points: 12,794
http://www.homedepot.com/p/Flotec-6-...0LTS/100066810
oldrivers (03-17-2014)
Old 03-17-2014, 03:35 PM   #4
Rewards Points: 256
ive only seen the systems meant for toilets and never seen that one , looks like the easy way to do it .
Old 03-17-2014, 08:53 PM   #5
Owner
LateralConcepts's Avatar
If you plan for it to work for a while, I'd use a better pump system. Use a brand name like Liberty or Zoeller. Search "Liberty 404"
Brad Penske, Operations Manager - Coeur d'Alene, ID
Lateral
CONCEPTS, LLC - Sewer & Septic Line - Video Inspection, Locating, Consulting
(208) 818-8241
Like us on Facebook!
LateralConcepts is offline   Reply With Quote
The Following 2 Users Say Thank You to LateralConcepts For This Useful Post:
oh'mike (03-18-2014), oldrivers (03-18-2014)
Kitchen drain making basement washer drain back up... mjd616 Plumbing 6 03-15-2014 12:33 PM
Plumbing Issue fly guy Plumbing 8 10-27-2013 09:02 PM
First Floor Laundry Room Floor Drain install? hammerlane Plumbing 9 10-21-2011 10:12 AM
Basement bathroom sink drain line on a slight upwards slope an issue? dtran Plumbing 7 01-10-2010 06:05 PM
Help with construction of laundry sink VokinLoksar Plumbing 3 07-06-2008 07:42 PM
