What's The Best Stuff To Unstick A Nut?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-28-2012, 06:36 PM   #1
Been at it for 45 years
This Old Spouse's Avatar
Rewards Points: 79
What's the best stuff to unstick a nut??
Trying, trying, trying to get the nut off a kitchen faucet I'm replacing. Soaked the heck out of it with WD40 but still no joy. The faucet is from 1987 so I think the nut is steel on a brass treaded pipe. Then there's the lock nut to the faucet handle. Brass on brass there.
I gave up on my basin wrench and took the sink out.
This Old Spouse is offline   Reply With Quote
Old 02-28-2012, 06:41 PM   #2
Lightfoot's Avatar
Rewards Points: 272
since you've got the sink out, have you tried heat?
Or a dremel type tool to cut the nut.
Lightfoot is offline   Reply With Quote
Old 02-28-2012, 11:38 PM   #3
Rewards Points: 81
Best stuff I've found for this situation is called "PB Blaster." Its automotive. You spray it on a few hours (or the night before) and then crank away the next day.
JeepNick is offline   Reply With Quote
Old 02-28-2012, 11:50 PM   #4
Rewards Points: 14,306
Box end wrench and a hammer to shock it loose.
Deep well socket and a rachet may also work.
Old 02-29-2012, 06:58 AM   #5
Joe F's Avatar
Rewards Points: 294
The best stuff I've ever used is called Mouse Milk. The main ingredient is oil of wintergreen.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 02-29-2012, 07:11 AM   #6
Rewards Points: 79
I did try that with no luck. I'll try the ratchet again. And I'll look for some PB Blaster and/or Mouse Milk. Thanks!
Old 03-15-2012, 03:23 PM   #7
Rewards Points: 79
I know you're all excited to hear how this all ended up. I finally brought the whole damn sink home and sawed through the nut. Which, by the way, STILL didn't just fall off. Oh no, I ended up sawing off the rest of the valve and using a wrench to get it off. I was contemplating getting a whole new sink, but tenacity finally won out.
Thanks for all your suggestions!
fuzzy stuff growing on basement floor peggy whiting Flooring 6 11-06-2010 11:46 AM
Am I using the right stuff? davecuz Flooring 2 10-18-2010 10:35 PM
Great Stuff and 6 mil poly vapour barrier maljeff Building & Construction 4 09-30-2010 12:26 PM
PL Premium - what can't you use this stuff for???? irishtimes101 Plumbing 2 09-01-2006 10:05 PM
Is it normal to see green stuff on the supply pipes KUIPORNG Plumbing 2 06-30-2006 11:21 AM
