Whats This? - Plumbing - DIY Home Improvement | DIYChatroom
Old 08-11-2011, 05:46 PM   #1
Whats this?
Just bought a house that Has two of these under The kitchen sink. One on each water line going to the faucet.
What is it?
Thanks for your help.
Jorgeelizondom is offline   Reply With Quote
Old 08-11-2011, 05:53 PM   #2
the white item in back is a weight for the sprayer hose,, the other connection is something rigged, no way those elastic bands are helping, I would change out the supply lines,, no, I"m not a plumber but that connection doesn't look safe.
LIVING THE DREAM
DUDE! is offline   Reply With Quote
Old 08-11-2011, 06:23 PM   #3
That looks like a faucet riser for a commercial 3 compartment sink.
Master of Cold is offline   Reply With Quote
Old 08-11-2011, 08:31 PM   #4
I apologize for the lack of knowledge, but what is it for?
Old 08-11-2011, 08:35 PM   #5
Rewards Points: 558
where is the other end attached to?
epson is offline   Reply With Quote
Old 08-11-2011, 08:45 PM   #6
That's what the guy that installed it was saying...
Old 08-12-2011, 09:56 AM   #7
One end to The faucet the other to the water line.
Old 08-12-2011, 06:55 PM   #8
Rewards Points: 558
Ok then what’s with the rubber bands?
Old 08-12-2011, 09:25 PM   #9
Johnboy555's Avatar
Those aren't "rubber bands" it's copper wire that's corroded. The only thing that I can think of is it's some kind "stop" (shut-off valve) the kind used in a tub valve for apartments (they don't shut off the entire appt building to repair valve.) Why the wire is there is beyond me.
Johnboy555 is offline   Reply With Quote
Old 08-13-2011, 08:06 PM   #10
I think you are right. It's some sort of stop valve. It has a large slot on the flat end for a screwdriver.
For a short period I thought it was a flow regulator but the house does not have unusually high pressure.
The other stuff I think is Teflon tape in bad shape.
Thank you very much for your input.
As for the wire... I think we will never know the [intended!] purpose !!
Old 08-13-2011, 09:00 PM   #11
Its missing duct tape.
