What Is This?? And What Does It Do?? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-24-2013, 12:37 AM   #1
Rewards Points: 14
What is this?? and What does it do??
We recently purchased a 50+ year old cabin. This is on the outside. I can't seem to turn it on or see that it turns anything else on. Does anyone know what it is or what it might do? I don't know why so much pipe would need to be exposed on the outside of the house. Thanks for any help.
lubbockgolf is offline   Reply With Quote
Old 02-24-2013, 03:14 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
looks like a gas line
Old 02-24-2013, 04:17 AM   #3
DIY staff
Rewards Points: 7,174
You will need to see if it is still connected inside of the house----that might have been the hot and cold lines for an out door shower----I've seen that on beach houses----
Old 02-24-2013, 07:10 AM   #4
Rewards Points: 14,306
Where's the water heater in the house? If there is not one there now I guess that's where the old water heater was, old washer hook up?
All guesses since where not there to see it.
TarheelTerp (02-24-2013)
Old 02-24-2013, 08:48 AM   #5
Master Plumber
Javiles's Avatar
Rewards Points: 996
If that's the main water coming in, maybe an old filter system or water softener that was removed..
Experience is Knowing what to do next, Skill is knowing how to do it
http://www.americandrain.net
Javiles is offline   Reply With Quote
Old 02-24-2013, 09:31 AM   #6
Rewards Points: 350
It looks like some sort of galvanized gas or water pipe with a flex hose connecting it. Can't really tell from picture if that's a gate valve on the pipe or not.
Can you do a couple close ups of the valves that are pictured?
jmon is online now   Reply With Quote
