What To Watch For When Relocating Water Heater? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-24-2011, 01:06 AM   #1
Rewards Points: 150
What to watch for when relocating water heater?
Hi everyone,
I am looking into "relocating" a water heater. Actually, I have a tank less water heater in my detached garage all the way on the corner... this is about 30 feet from my bathrooms. I am not very happy with the performance of this unit, specially in the winter.
I would like to install a "regular" water heater on the outside wall next to my bathrooms. I believe this will ensure I get faster hot water and actually some true HOT water when needed.
I will need to "tap" the lines under my house to allocate for this new heater. More than likely I will hire a plumber to get this done for me... water and gas lines. I just want to make sure the plumber do a decent job by educating myself on the things to keep in mind when doing a job of this type.
Is there any problems with taping the closest lines with a T? Or any specific guidelines that need to be followed?
Thank you in advance.
Greg
gante is offline   Reply With Quote
Old 01-24-2011, 05:44 AM   #2
DIY staff
Rewards Points: 7,174
That question is to 'site specific' to give you any real guidance.
I suggest you use a high efficiency unit to avoid the need for a B-vent through the roof.
The piping need to be seen to figure the best route.---Mike--
water heater drip kdange1 Plumbing 6 10-29-2014 05:26 PM
How to properly drain and flush a hot water heater? speedster1 Plumbing 9 04-17-2012 09:55 PM
Oil fired furnace and hot water heater question steveinpa Plumbing 3 08-10-2010 08:42 AM
Water connections for new water heater diggerdave Plumbing 16 03-16-2009 10:36 AM
Gas Hot Water Heater - Help? MaximumAsh Plumbing 22 03-13-2009 10:57 AM
