What Type Of 4" Drain Pipe Is This & What 90 To Use - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-31-2012, 05:59 PM   #1
Rewards Points: 2,516
What Type Of 4" Drain Pipe Is This & What 90 to Use
Take a look at the photos. This drain is to pick up water in a kind of swale and direct it out the other end of the patio. What type of pipe is this and what type of 90 do I need to get it to grade level after I backfill around patio. The OD of the pipe is about 4 & 3/16 inches
What Type Of 4" Drain Pipe Is This & What 90 to Use-111.jpg   What Type Of 4" Drain Pipe Is This & What 90 to Use-222.jpg   What Type Of 4" Drain Pipe Is This & What 90 to Use-333.jpg
hammerlane is offline   Reply With Quote
Old 07-31-2012, 07:48 PM   #2
Household Handyman
Rewards Points: 1,408
Is that a "rubbery" type coating within the pipe? IF so, then I have seen, used something like that in a plant where we pumped "waste" chemical through it so that we could process the "waste". The PVC, if that is what the white piping is, could/would handle the corrosive chemical but the coating made it somewhat silent. Yes, it did make a noise when the pump kicked in to pump out the pit. This is a drain line for your use remember, NO pressure: Maybe find a PVC or DWV pipe that would fit inside this existing piping and glue it into place, then you should be able to find appropriate fittings to do what you want from there.
The Following User Says Thank You to Thurman For This Useful Post:
hammerlane (08-01-2012)
Old 07-31-2012, 07:57 PM   #3
never having seen a pipe like that i dont know if it possible to solvelent weld pvc to it. best best is a rubber boot made for 4inch pipe clamped to that then clamped to a stub of 4 inch pvc with a 90 glued to it.
pardonme2711 is offline   Reply With Quote
The Following User Says Thank You to pardonme2711 For This Useful Post:
VIPlumber (07-31-2012)
Old 07-31-2012, 10:48 PM   #4
Rewards Points: 636
that looks similar to hancor or ADS brand triple wall drainage pipe
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
jaydevries is offline   Reply With Quote
Old 07-31-2012, 11:02 PM   #5
Plumber
TheEplumber's Avatar
Rewards Points: 564
I looked on google (triple wall drain pipe)- Is this it?
http://www.ads-pipe.com/en/product.a...E_/_Smoothwall
Or this?
http://www.baughmantile.com/triplewall.htm
I've seen your pipe before on job sites but never worked with it.
Google had a few more listings for stores and manufacturers.
Appears that PVC DWV fittings will work. Not sure about glue though.
Old 08-01-2012, 04:46 AM   #6
Rewards Points: 352
Polyethylene Triple Wall Solid Drainage Pipe. Right off the home depot website
plumberinlaw is offline   Reply With Quote
Old 08-01-2012, 05:44 AM   #7
Heres a close up. Looks like Hancor from Lowes.
What Type Of 4" Drain Pipe Is This & What 90 to Use-dsc_0003.jpg   What Type Of 4" Drain Pipe Is This & What 90 to Use-dsc_0004.jpg
Old 08-01-2012, 05:50 AM   #8
Looks like Hancor makes a snap elbow or a tee that I can use to 90 up to grade level
Old 08-01-2012, 07:21 AM   #9
Found some fittings online. The snap 90 then a surface inlet cover.
Drain pipe leak, quick fix? Ultrarunner2017 Plumbing 15 02-15-2012 08:57 AM
Leaky Washing Machine Drain Pipe sweetwaters Plumbing 17 02-14-2012 08:50 AM
Adding washer to basement with no way to vent drain pipe General Plumbing 6 12-26-2010 11:11 AM
Tap 2" Drain Pipe into 4" PVC Main Sewer Drain Pipe brmatthews Plumbing 3 12-20-2010 07:49 PM
New bathroom drain pipe leaks PAK Plumbing 2 07-29-2008 09:36 AM
