What Toilet Can Handle Big Dumps? - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-08-2011, 11:04 AM   #1
What toilet can handle big dumps?
I was wondering what peoples opinions are on what the best toilet is, that can handle large amounts of waste. My sister is very frustrated with all the toilets in her house because they always clog. People in her family take very large dumps and the toilets clog every single time. No plumber has been able to help. They have American Standards, and have been through a couple of different types of toilets, including Kohler and she doesn't want toilets that flush loud like a rocket. What is your opinion on which is the best non-clogging toilet?
lotusmachine is offline   Reply With Quote
Old 02-08-2011, 11:08 AM   #2
Experienced
Jackofall1's Avatar
The bigger the flush valve the less likely to clog. I would be looking for a toilet with a 3" flush valve. other than that, not sure what else you could do, other than layoff the high fiber diets........
Mark
Old 02-08-2011, 11:21 AM   #3
Rewards Points: 3,130
Home Depot has "flush" ratings for the toilets they sell. The higher the number, the greater the flushing power. You might also consider an air-assisted unit.
Old 02-08-2011, 11:22 AM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,638
Ayuh,... A Portapotty in the backyard,..??
Old 02-08-2011, 11:26 AM   #5
Experienced
Jackofall1's Avatar
Multiple flushes during dump cycle works to!
Old 02-08-2011, 12:15 PM   #6
concretemasonry's Avatar
Rewards Points: 2,626
Buy a $7000 Japanese (Toto/Toyo ?) toilet that follows with a wash, rinse, dry and flush cleaning. - I saw one at a home in China and it even plays music and closes the lid automatically.
Dick
concretemasonry is online now   Reply With Quote
Old 02-08-2011, 01:18 PM   #7
Homerepairguy's Avatar
Rewards Points: 998
After a LOT of research, I bought a Toto Drake toilet with 1.6 gallon flush for our master bathroom. It has excellent user feedback for being a great non-clogging toilet compared to their previous toilets that needed a plunger besides them. It's a gravity feed toilet and cost me about $260. A bit expensive but I think worth it if I never have any clogging problems with just normal use. (kids throwing stuff in toilets don't count of course )
I wanted a 1.6 gallon flush (instead of a 1.28 gallon flush) since that's the highest volume flush that's permitted now. I think there's Toto toilets with 1.28 gallon flush that are said to work well but I just feel better with the max flush volume permitted.
HRG
Homerepairguy is offline   Reply With Quote
Old 02-08-2011, 01:34 PM   #8
I have the same one - it works great. Almost never need a plunger!
HRG
player01 is offline   Reply With Quote
Old 02-08-2011, 02:30 PM   #9
ICF built home
I also recommend the Toto Drake. I have 3 of them in our house. in the last 3 years since moving into our new built home I have not had to use the plunger. It sits forlorn somewhere in the basement.
In our old home we had Mansfleld and American standard toilets I believe. Both clogged regularly.
The extra money for the Toto Drake has been worth every penny.
In my search I found the MaP Testing (Maximum Performance Testing) by the California Urban Water Conservation Council to be the best source of information on toilets and their performance.
Here is their website:
http://www.cuwcc.org/MaPTesting.aspx
Here is the PDF describing their test protocols:
http://www.cuwcc.org/WorkArea/linkit...d&ItemID=13732
and finally here are the most recent toilet test results:
http://www.cuwcc.org/WorkArea/linkit...d&ItemID=16080
Even if you decide to go with something else you can use the above info for a real comparison. The advertising put out by the manufacturer is a bunch of hooey. Read through the report and you will be amazed at some of the name brand toilets that don't work very well at all.
I am so glad I found this report before I bought. Remember for the most part you will get what you pay for... cheap generally means a "Crappy" flush, pun intended.
I hope this helps.
My final recommendation is to buy the ADA version (taller seat) of whatever brand you go with, especially if you are a tall person. It makes the toilet so much more comfortable to use.
Dragon is offline   Reply With Quote
Old 02-08-2011, 08:45 PM   #10
Rewards Points: 150
I had a guy tell me "My turds are about 3 inches wide and 6 inches long" he wanted a way to flush with out it clogging but, only wanted to spend $100... I gave him a paint mixing stick to break those boys up
Docwhitley is offline   Reply With Quote
The Following User Says Thank You to Docwhitley For This Useful Post:
r0ckstarr (12-12-2015)
Old 02-08-2011, 09:18 PM   #11
Rewards Points: 286
I bought an American Standard Cadet 4 at HD after one of my kids fiinally got something stuck in the toilet trap that I couldn't get out. It had the highest flush rating at the time and cost 200 dollars. They had a video with a guy flushing a bucket of golf balls down this toilet. It's been in for about 4 years, haven't had a clog yet.
Jim F is offline   Reply With Quote
Old 02-08-2011, 09:41 PM   #12
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Mark
It's not just the water passage size from tank to bowl. You can get various sizes of traps as well. On top of that, you want the trap to be glazed the entire way.
I have a very inexpensive Eljer 1.6 gpf, elongated bowl that works exceptionally well. I think it was like $125 or so (maybe less as it was on sale).
It has a 3" passage from tank to bowl and (I think) a 2 1/8" trap diameter and full length glazed.
If you can stop this baby up, it's time to see a doctor.
Old 02-09-2011, 09:02 AM   #13
i had a customer who's son was on medication making his "dump" very large and hard (insert bad joke here ). she had bought 3 different wc's at HD that he managed to clog easily. after looking around on the internet I got her a Caroma Carravelle http://www.amazon.com/Caroma-989646W.../dp/B0014E7QIA that she has had for over a month now without one clog. I was very amazed with the flush when i installed it, and the trapway on it was over 3". the only disadvantage was that being a dual flush, very little water sits in the bowl so it requires more cleaning. but thats a heck of a lot better than calling a plumber every month to clear a toilet
the_man is offline   Reply With Quote
Old 02-09-2011, 09:42 AM   #14
Rewards Points: 1,010
This has to be the classiest post of the day
Anti-wingnut is offline   Reply With Quote
Old 02-09-2011, 09:58 AM   #15
the Musigician
DangerMouse's Avatar
I don't CARE it makes a bit more noise than a normal toilet, I love my FlushMate/Crane pressure assisted throne!
That sucker will flush just about anything.
DM
Handle on Toilet MUST be held down throughout flush mr_trotta Plumbing 20 12-24-2014 04:35 PM
Grossly insufficient water supply to toilet wasting water? mysterylectric Plumbing 8 01-17-2012 11:19 AM
Help me check my logic on clogged drain and overflowing toilet Southlake_Ed Plumbing 10 01-05-2010 07:52 PM
Toilet Flush Handle skittlzski Plumbing 8 02-22-2009 10:29 PM
Toilet jpark Plumbing 18 01-05-2009 07:12 AM
