Old 07-25-2008, 09:54 AM   #1
what is this thing called?
I need a pipe fitting - similar to an elbow fitting - that needs to be welded on. I found a picture on a foreign website, but i can't order from there and i need to know what it is called in english, so i can find it on the web.
Any help?
farag is offline   Reply With Quote
Old 07-25-2008, 10:17 AM   #2
Doing it myself
Alan's Avatar
I have never seen anything like that in my entire life.
Is that for water supply? It doesn't look like it would be an 'approved fitting' as required by code, but I've been wrong before....
Journeyman Plumber
Old 07-28-2008, 07:54 AM   #3
the Musigician
DangerMouse's Avatar
that looks like it's made from automotive exhaust tubing....(note side welds) have you tried AUTOZONE? is this a plumbing piece? for what? welded where to what? hard to imagine it's for plumbing.....(you DID post in the plumbing section)
DM
Old 07-28-2008, 08:57 AM   #4
LOL.. sure looks like a tail pipe... Is this plumbing project in a Volkswagon?
Won't be the first time somebody made something work.
Big Bob is offline   Reply With Quote
Old 07-28-2008, 09:36 PM   #5
Licensed Master Plumber
mstplumber's Avatar
It looks like some type of saddle fitting. This is a fitting that is designed to be welded onto a pipe after the pipe is cut out to match the footprint of the fitting. It certainly looks too thin to be a plumbing fitting. A little more info about size and application would help ID this.
Mstplumber
Check out my goofy video for my new
mstplumber is offline   Reply With Quote
Flooring vs Subflooring (whatever it is called) lifeontherun Flooring 3 07-13-2008 04:03 PM
Flooring vs Subflooring or whatever it is called lifeontherun Flooring 10 07-09-2008 09:14 PM
lost power to 1 thing in 4 different places... ManMythLegend Electrical 31 12-19-2007 01:57 PM
What is this part of the gutter called? DanBress Roofing 4 11-04-2007 08:41 PM
Is there such a thing? wiscborn Plumbing 6 06-29-2007 03:19 PM
