What Are These Pipes For In The Basement. - Plumbing - DIY Home Improvement | DIYChatroom
Old 02-19-2012, 10:33 PM   #16
Rewards Points: 616
right click on picture and select open with incognito then you can see text
jaydevries is offline   Reply With Quote
Old 02-19-2012, 10:34 PM   #17
Yes this is existing pipes. I will try to pour some water down thevshower pipe here soon.
jkpyke is offline   Reply With Quote
Old 02-19-2012, 10:45 PM   #18
Plumber
TheEplumber's Avatar
Rewards Points: 350
That's a sweet trick- thanks
All I see is a toilet and lav. A tub or shower will require breaking the floor up since their traps need to be below the floor.
Do you see any capped pipes in the ceiling for future venting?
Also, where does the existing drain exit the house?
The toilet riser appears to have the hub from its 90 exposed above the concrete- thats not good, hard to set a flange on that.
Old 02-19-2012, 11:11 PM   #19
Well didnt have to pour anything down the drain. Had a bunch of standing muck or something else down in the and a small fly came out at me. Guess it is time to call a plumber. You guys are right about the stem for the toilet it is above the concrete....not good. There is nothing else going out to a vent
Old 02-19-2012, 11:32 PM   #20
Plumber
Rewards Points: 350
Don't let that little fly scare you go ahead, pour water down the 2" and see what happens.
Old 02-26-2012, 08:51 PM   #21
Well the good news for me is that all the muck flushed out by just pouring a picture of water down the tub drain. Then I can see standing fresh water at the bottom of the pipe. So from that I am assuming I have the necessary trap I need. I guess my next question would be, do I need a vent for the sinks or can I just run a drain. Iive in MI if that helps.
Old 02-26-2012, 09:09 PM   #22
Rewards Points: 616
where is your sink going and did you look around for a pipe just hanging out between floor joist or around existing drain
"be careful at listening to just one persons advise" said me
"be careful at listening to just one persons advise" said myself
p.s. not all i say is a fact but not all i say is my opinion.
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 37 07-06-2015 08:40 AM
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 02:13 AM
running pipes in outside wall (Basement) BlueBSH Plumbing 1 10-18-2010 11:30 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
