Old 08-27-2011, 09:33 PM   #1
What are these pipes for in the basement.
We have an unfinished basement and we were wondering if anyone would know or could tell us what the 3 pipes are for going into the concrete.
jkpyke is offline   Reply With Quote
Old 08-27-2011, 09:43 PM   #2
Super Moderator
Typical bathroom rough in.
However I don't see the vent for the toilet---should be another 2" pipe near the 3" pipe.
jkpyke (08-27-2011)
Old 08-27-2011, 09:43 PM   #3
Code05's Avatar
I am not a plumber, but I have a pretty good idea.
Top left is a clean out going to a main sewer section. It has a drain or a vent
on the left going up.
Small one below is a future section drain to a sink or shower.
Big one on the right is a future connection to a toilet.
Code05 is offline   Reply With Quote
The Following User Says Thank You to Code05 For This Useful Post:
jkpyke (08-27-2011)
Old 08-27-2011, 09:45 PM   #4
Code05's Avatar
Wahoo, I was right.
The Following 2 Users Say Thank You to Code05 For This Useful Post:
jkpyke (08-27-2011), oh'mike (08-27-2011)
Old 08-27-2011, 10:18 PM   #5
Thread killer
Is it possible the pipe coming off the wye is the venting and the drain continues under the wall?
Canucker is offline   Reply With Quote
Old 08-27-2011, 10:34 PM   #6
Well, these are for drainage.
Butch. is offline   Reply With Quote
Old 08-29-2011, 07:05 AM   #7
Super Moderator
Run water into the pipes---see what's going on----Look for the toilet vent----
Any plumber worth his salt can check that with a sewer camera and find the vent or the lack of one.
Old 08-29-2011, 09:10 AM   #8
Not necessarily. The applicable code where I live (IRC 2003) handles venting quite differently from the UPC. Among other things, it does not require vents for toilets. Vents provide an air path to prevent water from being sucked out of the traps. Well, a toilet is essentially a large trap you WANT to ber sucked out when you flush.
Old 02-19-2012, 08:26 PM   #9
Thanks for the replies. Very helpful. So if this is typical rough in, and if we were looking to have a sink, toilet, and tube/shower, could we put a sink in front of the toilet with the sink drain running down to the toilet drain, and then put a shower on the left side of the picture in front of the cleanout?
Old 02-19-2012, 08:48 PM   #10
call me E
TheEplumber's Avatar
You can put any fixtures you want there. Looks like you have a 4" building drain servicing that area. You just need to make sure it's plumbed correctly.
Sounds like you plan to remove some concrete?
Old 02-19-2012, 08:53 PM   #11
ok big pipe gets cut off flush then toilet flange then toilet , other pipe could be sink or tub or shower need to take off cap poor water in pipe shine flashlight done pipe and do you see standing water and what size is the inside of pipe , and like someone else asked the pipe going up the wall to the upstairs is there something that drains into it and what is the outside size of it or you might just look on pipe at righting it will say the size
jaydevries is offline   Reply With Quote
Old 02-19-2012, 09:49 PM   #12
Here is a quick and dirty picture that I drew up of the top view of the drains. Hopefully this helps better explain of what I have. I guess my biggest question is, would I have to break concrete? I would like to put a bathroom downstairs and will eventually but it will all depend money. Seams like breaking up the concrete, if I have to, will be a big expense. Hopefully the pic. turns out, if not I will repost again.
Old 02-19-2012, 10:15 PM   #13
need to remove 2 inch cap and pour water in to it if it has standing water in it. it has a trap for a shower
Old 02-19-2012, 10:23 PM   #14
e plumber or someone else with long term permitable plumbing background correct me if i am wrong but the basement bath since on a different floor can not be vented through the 3 inch drain
and if that is true then start looking around between floor joist for a pipe just hanging there to be used for vent i know irc states if roughing for future use bath a vent most also be roughed in
but that is only if done to code and inspected
Old 02-19-2012, 10:29 PM   #15
call me E
Are these existing pipes? I can't read all the text
Cutting out a concrete basement floor jeffhoward001 Building & Construction 21 01-17-2012 09:51 PM
what's the consequences of a well insulated basement diy001 Building & Construction 1 06-12-2011 02:13 AM
At a crossroads in my basement project - waterproofing help needed callisto9 Building & Construction 35 10-28-2010 03:01 AM
running pipes in outside wall (Basement) BlueBSH Plumbing 1 10-18-2010 11:30 AM
Old Home - Basement addition insulation vapor barrier question 1870 Building & Construction 0 10-14-2010 08:36 AM
