What Are These Pipes For? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-07-2012, 09:57 AM   #1
Rewards Points: 45
What are these pipes for?
Just moved to a home that was built in 2002, and I've got this U shaped pipe configuration with a quarter turn shut off valve in the garage. I currently store two 55 gallon barrels under it that contain drinking water, and it would be great if I could cut the pipe and put a fitting on it to allow me to fill the barrels up. What are these pipes for? How do I determine what side of the shut off valve the water is still flowing? Is a compression fitting a viable option? I won't be attempting to sweat pipes. Thanks in advance.
Austin83 is offline   Reply With Quote
Old 11-07-2012, 09:59 AM   #2
DIY staff
Rewards Points: 7,174
Abandoned water softener hook up-----leave the valves in the 'ON' position---that is your main water line----
Old 11-07-2012, 10:04 AM   #3
DIY staff
A spout could be soldered into the line to fill your barrels-----use one with a built in vacuum breaker--
Old 11-07-2012, 10:07 AM   #4
Rewards Points: 13,446
Why in the world would you be storing water?
That's 822.8 LB of weight sitting there.
Old 11-07-2012, 10:26 AM   #5
Rewards Points: 45
I'm not a doomsday prepper, but I like to keep extra food and water on hand in case of any natural disasters, civil unrest, water disruptions, boil warnings, etc.
Drain Pipes, Walls and Studs mattaparity Plumbing 2 12-18-2011 07:22 AM
Combining vent pipes in the attic. a4aj Plumbing 5 02-04-2010 11:20 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK Remodeling 7 11-04-2009 08:10 AM
How to (retrofit) insulate/air seal cantilever with hot water pipes in it? KatieAK HVAC 5 11-01-2009 08:15 PM
insulating heated garage(retrofit)- insul. & pipes KatieAK Building & Construction 0 10-25-2009 09:03 PM
