What Is The Term For The Rubber Coupling With 2" Ring Clamps? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-14-2012, 06:25 PM   #1
Rewards Points: 264
What is the term for the rubber coupling with 2" ring clamps?
I'm trying to order 3/4" ones online because local stores don't see to carry them that small.
tibberous is offline   Reply With Quote
Old 11-14-2012, 06:37 PM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 904
Are you talking about Fernco couplings? good luck finding one that small. You might be better of using radiator hose and clamps-
The Following User Says Thank You to TheEplumber For This Useful Post:
gregzoll (11-14-2012)
Old 11-14-2012, 06:47 PM   #3
Rewards Points: 264
Found em on eBay:
3/4" Fernco Pipe Connector Coupling
Expensive, but nice if you need to take something apart in sections and can't use threaded.
Old 11-14-2012, 06:59 PM   #4
funfool's Avatar
Rewards Points: 534
I wonder what you will use them for.
Only thing I can think of in 3/4" is a supply line, do you think they will hold the pressure with hose clamps?
funfool is offline   Reply With Quote
Old 11-14-2012, 07:05 PM   #5
Rewards Points: 264
Yeah, there really leak proof. Obviously I'm just using them for utility pumps, I doubt they'd hold back 40 psi.
I generally run all my water lines 3/4", since all but the beefiest pumps tend to have a 3/4" outlet (I have a 1 hp cast iron one with an 1 1/2 outlet, always wanted to use it to make the worlds more wasteful shower -- it would have to have a separate water holding tank, probably would backup the drain)
Pipe insulation: Foam, Rubber, Other? IckesTheSane Plumbing 40 03-21-2016 06:57 PM
Rubber coupling to cast iron sesp55 Plumbing 7 03-07-2012 06:31 PM
reuse rubber PVC coupling? csab_ Plumbing 21 01-21-2012 10:23 PM
Using a rubber coupling instead of PVC coupling sukhenkoi Plumbing 2 04-05-2011 06:53 AM
Leak at rubber coupling in stack WillK Plumbing 7 03-14-2011 01:37 PM
