What Is This Stuff I'am Working With? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-24-2008, 09:34 PM   #1
What is this stuff I'am working with?
My brother and I bought a town home as a fixer upper to re-sell,it's about 23 yrs old,and the supply lines in the home are this gray plastic pipe with band clamps at the joints,I'am sure there must be a trade name for this junk
Everything I touch or even look at to long leaks,some of the joints you could just move a hair and they stop leaking,others a narrow worm clamp around the band has worked,and I've been as carefull as I can replacing the fixtures,
gotboost is offline   Reply With Quote
Old 11-24-2008, 09:41 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
Yep. It's called "junk" or "the stuff that spawned a class action lawsuit".
also known as polybutylene pipe or PB pipe.
search polybutylene lawsuit. You'll find a lot on it.
Old 11-24-2008, 09:55 PM   #3
skyman's Avatar
Exclamation
Yep.......
skyman is offline   Reply With Quote
Old 11-24-2008, 11:38 PM   #4
Registered User
Termite's Avatar
That stuff caused a lot of problems for a lot of people. Get as much of it out as you can! Switch to PEX, CPVC, or copper.
Old 11-24-2008, 11:40 PM   #5
nap
You talking to me?
nap's Avatar
there is at least one lawsuit againt PEX. Haven't read it so not sure what it's about.
I stick with good old copper.
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 02:32 PM
Inside Fan not working BenH HVAC 20 07-08-2008 07:10 AM
Working with granite... SDeeter19464 Remodeling 5 06-14-2008 06:51 AM
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 02:47 PM
