What Sort Of Screws Should I Use To Fasten Toilet Flange To Slab? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-30-2013, 06:09 PM   #1
Rewards Points: 150
What sort of screws should I use to fasten toilet flange to slab?
Im going to mount a toilet flange to the concrete slab what sort of screws or fasteners should I use for this?
Arsinek is offline   Reply With Quote
Old 06-30-2013, 06:16 PM   #2
Rewards Points: 12,824
Tap Con.
Going to need a hammer drill to drill the holes.
Old 06-30-2013, 09:10 PM   #3
ScottFla40's Avatar
Agree with Joe and would add get a TapCon bit that corresponds to the size fastener your using...
ScottFla40 is offline   Reply With Quote
Old 06-30-2013, 09:32 PM   #4
Plumber
TheEplumber's Avatar
Rewards Points: 350
I usually use these--http://www.homedepot.com/p/Red-Head-...3#.UdDbzjtwotg
Drill a 1/4" hole- drop it in and set the pin--simple
Old 06-30-2013, 11:14 PM   #5
DIY Enthusiast
sublime2's Avatar
This right here is the way to go!
Tap con is NOT. Not reliable and can snap easily.
sublime2 is offline   Reply With Quote
Old 07-01-2013, 07:23 AM   #6
Davejss's Avatar
Rewards Points: 740
I've used hundreds of TapCons with great results. Use the correct drill bit, blow the dust out and drive the screw at low speed. If you ever need to remove the flange, just unscrew it. Try doing that with pins.
Davejss is offline   Reply With Quote
The Following User Says Thank You to Davejss For This Useful Post:
joecaption (07-01-2013)
Old 07-01-2013, 07:52 AM   #7
Lord of Slums
Rewards Points: 1,974
I use ss screws and plastic plugs. Tapcons are an awful choice
mj12 is offline   Reply With Quote
Old 07-02-2013, 08:39 AM   #8
Rewards Points: 150
What are the plastic plugs youre talking about?
Old 07-02-2013, 12:45 PM   #9
Lord of Slums
http://www.mscdirect.com/product/082...S&026=nv&025=c You will probably not get all the flage holes to line up, so if you miss one or two, no problem
Old 07-02-2013, 02:52 PM   #10
Plastic anchor are useless, I've never even had one work holding up a picture.
No way is a Tap-Con going to snap off.
I also have used hundreds for anything from setting walls on concrete slabs, installing toilets, installing outside faucets, and dozens of other jobs and yet to have one snap off.
A plastic anchor in a concrete slab will just be able to be pulled right up out of the floor.
Old 07-02-2013, 09:59 PM   #11
Lord of Slums
Ask anyone that professionally hangs steel doors for a living. Very few will use tap cons for too many reasons to list. Those plastic plugs are bullet proof when used in concrete. Glass shower door inclosures are all mounted with those plastic plugs. Here in Detroit every home that I own has a first floor done in concrete. That is all anyone that knows what they are doing using to anchor toilet flanges. If you think they are worthless then it is obvious you have not used them. Except maybe in drywall.
Old 07-02-2013, 10:28 PM   #12
Rewards Points: 150
Well maybe I could try the tapcons first then if those dont work try something else. I figure tapcons use the smallest hole right? So if I mess up that hole for the tapcon I could try a different fastener?
Old 07-02-2013, 11:00 PM   #13
DIY Enthusiast
sublime2's Avatar
Just hope you don't snap off the tap con in the hole.
Old 07-03-2013, 12:01 PM   #14
Lord of Slums
You will need just the right touch to get a tap con too work, no stopping, no slowing down. If you slow down it will snap. You can not stop and start again. After a few hundred you will understand what I am saying.
Old 07-03-2013, 03:45 PM   #15
Concrete & Masonry
Rewards Points: 470
I probably drive a few thousand a year, and usually take them out when done, and I have know idea what you mean. Sure, Tapcons can break or snap off if you leave too much dust in the hole, don't drill them deep enough, use a crappy bit, etc...., but I'd say less than 1% of the time do they break off for me...........
jomama45 is online now   Reply With Quote
Tile around Toilet flange. Tile will be at Higher Level than Flange? crayola110 Tiling, ceramics, marble 0 09-19-2012 07:07 PM
Uneven toilet flange alqugrub Plumbing 6 08-27-2012 09:16 PM
Changing out carpet for tile - toilet flange? M3 Pete Plumbing 4 02-16-2012 11:20 PM
How to prepare toilet drain pipe for toilet flange? brett.c.brown Plumbing 11 12-15-2011 08:41 PM
toilet flange Dave43026 Plumbing 3 11-05-2011 11:25 AM
