Old 08-12-2012, 08:46 PM   #1
What size tube spout for 5inch pipe?
So Im replacing a tub spout and the pipe sticks out exactly 5 inches from the wall. I bought a universal spout today from Lowes which was dumb because I knew it was going to be too short which it was, so Im going to return it. This universal one didnt even say what length it was supposed to fit on the package.
So how do I shop for a new spout that needs to fit a 5inch pipe?
Arsinek is offline   Reply With Quote
Old 08-12-2012, 08:56 PM   #2
Delete
Old 08-12-2012, 09:03 PM   #3
Originally Posted by joecaption View Post
A 5" pipe
Shower connections are 3/4" MPT.
Do you mean 5" long?
Why the 5"?
"the pipe sticks out exactly 5 inches from the wall"
Old 08-12-2012, 09:20 PM   #4
Delete
Old 08-12-2012, 09:30 PM   #5
What differance would it make if it's not exactly 5"?
Theres a gap between the spout and the wall.
Old 08-12-2012, 09:54 PM   #6
Post a picture if you can.
There's always a gap, it gets covered with an escuntion plate made for shower pipes.
http://images.drillspot.com/pimages/8089/808965_300.jpg
Old 08-12-2012, 10:10 PM   #7
Cut it? Use the one you bought then?
Evstarr is offline   Reply With Quote
Old 08-12-2012, 10:15 PM   #8
Unless you post the picture anyones just going to be guessing as to what the issure is.
Old 08-13-2012, 11:23 AM   #9
Assuming you have black pipe, just unscrew 5" pipe and install proper length for your tub spout.
A picture is worth a thousand words.
George6488 is offline   Reply With Quote
Old 08-13-2012, 11:31 AM   #10
You can make your own with two copper adapters and a short piece of 1/2 copper pipe, or buy the type of spout that has a rubber O ring in it that just slips over a piece of copper pipe and just solder on one 1/2 slip X 1/2" MPT adaptor. The spout gets held in place with a set screw from the bottom of the spout.
what size pipe to use for water main? Cainiac Plumbing 5 04-25-2012 12:57 AM
Question about copper pipe agroom Plumbing 3 10-27-2011 03:18 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 01:53 PM
Pipe size for hose bibb BigJimmy Plumbing 1 03-12-2007 02:53 PM
