-   -   What size tube spout for 5inch pipe? (http://www.diychatroom.com/f7/what-size-tube-spout-5inch-pipe-153461/)
Arsinek 08-12-2012 07:46 PM
So Im replacing a tub spout and the pipe sticks out exactly 5 inches from the wall. I bought a universal spout today from Lowes which was dumb because I knew it was going to be too short which it was, so Im going to return it. This universal one didnt even say what length it was supposed to fit on the package.
So how do I shop for a new spout that needs to fit a 5inch pipe?
joecaption 08-12-2012 07:56 PM
Delete
Arsinek 08-12-2012 08:03 PM
Originally Posted by joecaption (Post 987057)
A 5" pipe:eek:
Shower connections are 3/4" MPT.
Do you mean 5" long?
Why the 5"?
"the pipe sticks out exactly 5 inches from the wall"
joecaption 08-12-2012 08:20 PM
Delete
Arsinek 08-12-2012 08:30 PM
Originally Posted by joecaption (Post 987076)
What differance would it make if it's not exactly 5"?
Theres a gap between the spout and the wall.
joecaption 08-12-2012 08:54 PM
Post a picture if you can.
There's always a gap, it gets covered with an escuntion plate made for shower pipes.
http://images.drillspot.com/pimages/8089/808965_300.jpg
Evstarr 08-12-2012 09:10 PM
Cut it? Use the one you bought then?
joecaption 08-12-2012 09:15 PM
Unless you post the picture anyones just going to be guessing as to what the issure is.
George6488 08-13-2012 10:23 AM
Assuming you have black pipe, just unscrew 5" pipe and install proper length for your tub spout.
A picture is worth a thousand words.
joecaption 08-13-2012 10:31 AM
You can make your own with two copper adapters and a short piece of 1/2 copper pipe, or buy the type of spout that has a rubber O ring in it that just slips over a piece of copper pipe and just solder on one 1/2 slip X 1/2" MPT adaptor. The spout gets held in place with a set screw from the bottom of the spout.
