What Size Pipe Should I Install For Retrofit Drainage? - Plumbing - DIY Home Improvement | DIYChatroom
Old 07-01-2012, 08:51 AM   #1
What size pipe should I install for retrofit drainage?
I would like to drain an area that could flood. Will 2- 1.5 inch pipes drain a 10 gpm flow if the pipes are horizontally at floor level. I do not want the water level to raise more than 2 inches. Your assistance will be appreciated.
kimo_ie_jim is offline   Reply With Quote
Old 07-01-2012, 09:26 AM   #2
DIY staff
Rewards Points: 7,174
This is inside a building?
I suggest you use 2" pipe---more details please---how large is the room?
Concrete floor or wood frame?
existing building or new construction?
kimo_ie_jim (07-03-2012)
Old 07-03-2012, 06:33 AM   #3
Size of retrofit drain pipe ??
Thanks oh'mike for your response
The home is a slab home with no floor drain. I would like to install drain but not go through slab so in event of flooding water level would not go above 2 inches as I have sealed 2 inch high molding and drywall above I would like to protect, the floors are ceramic. The home is 1700 square feet. I would have the pipe exit at floor level in two locations and be protected from insects with use of down spout immersed in antifreeze camouflaged and protected from animals, etc. In such a case do you think 1.5 inch pipe will be adequate?
Old 07-03-2012, 07:24 AM   #4
DIY staff
What you are doing sounds like you want to just put drain holes to the outside of the house--shielded by pipe--
It would work--but will look like a retrofit---kind of a mess actually---
Are you trying to avoid disturbing the tiled concrete floor?
I would suggest cutting in a small sump pit---done neatly the tile around it would not be hurt---Let the water drain right into the pit--pump the water outside or into the houses drain system.
Just a thought---better drainage---pit with cover would look better than a couple of pipes drilled through the outside wall of the house.
Old 07-03-2012, 10:06 AM   #5
Doing it myself
Alan's Avatar
Rewards Points: 2,086
Why are you worried about the area flooding? Can we try to address that issue instead?
Journeyman Plumber
The Following User Says Thank You to Alan For This Useful Post:
oh'mike (07-03-2012)
Order of install? floor, drain pan, pipe fitting, washer mcherno Plumbing 1 06-26-2012 09:47 PM
what size pipe to use for water main? Cainiac Plumbing 5 04-25-2012 12:57 AM
Lead Drain Pipe Project Turbo98 Plumbing 33 01-30-2011 12:27 PM
Pipe Size pochi Landscaping & Lawn Care 2 07-04-2009 04:13 PM
reducing pipe size for sink drain bluebee1314 Plumbing 5 12-02-2007 01:53 PM
