What Size Meter Do I Need? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-20-2014, 12:17 PM   #16
Plumber
TheEplumber's Avatar
Rewards Points: 684
Originally Posted by Fairview
So why do we like to have 60# static rather than 10# static.
You can have 10 psi if you want- you'll just need larger pipes.
Old 01-20-2014, 12:51 PM   #17
Rewards Points: 1,322
Sure with a different size pipe, but with the same pipe static pressure differences changes flow dramatically. I'm not from MO but I'll have to be shown that it doesn't.
SeniorSitizen is offline   Reply With Quote
Old 01-20-2014, 05:28 PM   #18
Rewards Points: 1,958
If I have 80 lbs pressure then run water through a 1/4 inch pipe how many pounds pressure do you think is on that side?
We are talking about volume the GPM flow through the pipe. If his galvanized is rusting shut he may still have water to serve 1 fixture at a time. He may still read 60 lbs pressure when not using anything. His problem arises because when he runs 2 fixtures his piping does not allow the GPM flow he needs. He may also have an entire house stuff full of 1/2 inch only water lines for all I know.
A larger pipe allows more GPM out. Static pressure shows nothing in regards to flow rate. In some areas the water providers do that 1/2 inch meter thing here all the time. The houses experience no problems. I'm not saying I agree with them on this but it does work.
meter & main service panel upgrade from 100amp to 200amp CapeCod153 Electrical 2 03-26-2013 07:23 AM
Please help! Meter socket question fraghouse Electrical 9 11-27-2012 01:36 PM
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 09:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 06:53 AM
