What Size Meter Do I Need? - Plumbing - DIY Home Improvement | DIYChatroom
Old 01-19-2014, 11:28 PM   #1
What size meter do I need?
Added second floor bathroom. Total 2 in house now. Currently has 5/8 meter. One faucet open has good pressure and flow, but when I open another faucet , the pressure drops drastically. What should I check? House was vacant for 3 years/ water shut off. All new copper pipes except the main coming inside which is old. House built in 1920.
Aminoacid2014 is offline   Reply With Quote
Old 01-19-2014, 11:32 PM   #2
Lord of Slums
Rewards Points: 1,974
probably shut offs corroded under sink, replace them.
mj12 is offline   Reply With Quote
Old 01-19-2014, 11:34 PM   #3
Shower is also affected. All faucets affected.
Old 01-19-2014, 11:36 PM   #4
Rewards Points: 13,274
Also remove the aerators on the faucets to clean them out.
http://www.bing.com/images/search?q=...ucet&FORM=IGRE
plummen (01-20-2014)
Old 01-19-2014, 11:37 PM   #5
I already did that.
Old 01-19-2014, 11:46 PM   #6
Cheap enough and good practice to just change the shut offs.
Buy 1/4 turn stops. (the real name for the shut offs)
Old 01-19-2014, 11:47 PM   #7
Plumber
TheEplumber's Avatar
Rewards Points: 452
I bet the main is restricted to about the diameter of a pencil if it's been there since 1920
Old 01-19-2014, 11:49 PM   #8
I can do that.
Now is it typical to have 3/4 line coming into a 5/8 meter then 3/4 through house with 1/2 take offs?
Old 01-20-2014, 12:19 AM   #9
Rewards Points: 1,770
Originally Posted by Aminoacid2014 View Post
I can do that.
Yep. Question you need to answer is the pipe from the house to the street galvanized steel?
Old 01-20-2014, 12:22 AM   #10
I'm certain it's not copper. If it is galvanized would the city replace?
Old 01-20-2014, 12:17 PM   #11
Nope that would normally be you footing that cost. See if you can get estimates for a line push.
Old 01-20-2014, 12:42 PM   #12
Rewards Points: 702
What's the static pressure on your side of the meter?
Old 01-20-2014, 12:47 PM   #13
Static pressure readings will not show volume of water flow through a pipe.
Old 01-20-2014, 12:54 PM   #14
So I have a volume problem? Any one faucet open has perfect volume/ pressure.
Old 01-20-2014, 01:03 PM   #15
Rewards Points: 702
So why do we like to have 60# static rather than 10# static.
meter & main service panel upgrade from 100amp to 200amp CapeCod153 Electrical 2 03-26-2013 08:23 AM
Please help! Meter socket question fraghouse Electrical 9 11-27-2012 02:36 PM
Tiny elbows on meter? pcampbell HVAC 24 10-06-2009 10:54 AM
Water meter aggravations Ultrarunner2017 Plumbing 8 03-21-2009 07:53 AM
