What Size Ejector Pump Do I Need? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-14-2013, 11:47 PM   #1
Rewards Points: 870
What size ejector pump do I need?
I don't know how deep my basin is but it's laid in a concrete basin below grade and has a 20 1/2" lid. It services a full bath and laundry. The pump in there is from 1993 and I'm thinking it's best to replace it when I take ownership of the house. I haven't pulled it out yet.
I would like to get a Zoeller but unsure which model. There are many to chose from. Advice?
edit - i actually posted this last month but didn't get a response and forgot about my post. So this is a bump.
Daugela is offline   Reply With Quote
Old 05-14-2013, 11:58 PM   #2
Doing it myself
Alan's Avatar
Rewards Points: 2,086
What is the head pressure that the pump has to overcome to achieve gravity?
Journeyman Plumber
Old 05-15-2013, 12:06 AM   #3
Rewards Points: 870
Without being there to measure, I'm thinking about 10 feet. This would include the pump being 2 feet deep in the basin and 8 foot ceilings....Actually if you add an additional foot above the ceiling for the waste line, maybe 11 feet?
I like the Zoeller 267, but I'm not following the sizing chart on the Zoeller website. Money is not an option here. Best quality for my needs.
Old 05-16-2013, 09:58 AM   #4
Doing it myself
Alan's Avatar
There isn't really a good/better/best in your situation. Zoeller is a solid pump manufacturer. I also like liberty's pumps.
At any rate, when you're reading the chart, basically on the bottom it's showing you flow rate in gallons per minute, and on the left side is your elevation that you have to overcome. If you look again, you'll see that as the elevation increases, the gallons per minute decrease. In your situation you really have no need for something fancy or expensive.
I do however prefer a pump that has a pigtail style float rather than the one attached to the side of the pump with a rod.
Journeyman Plumber
Old 05-16-2013, 10:03 AM   #5
Rewards Points: 870
I'm not sure which chart you're looking at. On the Zoeller website, the only chart by the pumps talks about the tank diameter vs. gpm. My diameter is 20 1/2 which isn't listed here. Are you looking somewhere else?
Old 05-16-2013, 07:12 PM   #6
Rewards Points: 1,700
use a 1/2 HP zoeller shark grinder pump.
Old 05-16-2013, 11:11 PM   #7
Doing it myself
Alan's Avatar
When you click on a particular pump "family" look at the performance curve link on the left of that screen.
It should look like this.
https://app.qleapahead.com/rtp/tools/77567-63.gif
Journeyman Plumber
Old 05-16-2013, 11:31 PM   #8
Rewards Points: 870
Ok but what am I looking for here?
All these pumps can carry water up 10 feet at a certain GPM, but which is correct for my application?
Old 05-16-2013, 11:36 PM   #9
Doing it myself
Alan's Avatar
10 feet is nothing for any sewage ejector. Like I said, you don't really need anything fancy for your application. Zoeller makes nice pumps, and anything you get from them is going to be solid.
You said one bath, right? Your max input if your shower is letting loose, the sink is on, and the toilet is running full bore is somewhere around 10 GPM.
Journeyman Plumber
Sink Size Specs - Advice needed donvaz Kitchen & Bath Remodeling 1 08-12-2012 02:39 PM
wire size for 1575 inverter 15' from battery bluemoonshine Electrical 8 12-28-2011 10:49 AM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Determining Boot/Register Size Earnie HVAC 15 12-31-2009 06:00 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
