What Is Sink Drain/tub Drain Piping Called? - Plumbing - DIY Home Improvement | DIYChatroom
Old 03-21-2013, 09:05 PM   #1
Rewards Points: 150
What is sink drain/tub drain piping called?
I was thinking about trying to convert part of my tub drain to the plastic pipe that uses those screw on compression fittings. Id like to know what its called so I can research it.
It says its 1 1/2 inch but its not the same size as 1 1/2 inch pvc pipe.
Arsinek is offline   Reply With Quote
Old 03-21-2013, 09:14 PM   #2
Rewards Points: 13,716
http://www.homedepot.com/p/Watts-1-1...-5CP/100677379
Then you use a 1-1/2 adapter.
http://www.bing.com/images/search?q=...ectedIndex=277
Old 03-21-2013, 09:21 PM   #3
Rewards Points: 150
Thanks.
After looking around it doesnt really seem to have a name. Plastic tubing was the closest thing. Searching for slip joint brought up a lot of stuff.
Old 03-21-2013, 10:14 PM   #4
Rewards Points: 1,952
Tubular tub waste
The Following User Says Thank You to Ghostmaker For This Useful Post:
TheEplumber (03-22-2013)
Old 03-21-2013, 11:57 PM   #5
Rewards Points: 866
Joe Caption is on the money, again. I just had an old tub pulled and replaced with a new tub and I paid for new ABS "Trip Lever Bath Drain". That is what Watts, the manufacturer, calls the set I bought at Home Depot. I think some call it a waste/overflow line.
Klawman is offline   Reply With Quote
Old 03-22-2013, 03:56 PM   #6
most people call it polyethylyne
zcs20027 is offline   Reply With Quote
Old 03-22-2013, 06:01 PM   #7
Rewards Points: 150
Ill have to take a pic of the contraption I came up with.
Old 03-29-2013, 10:51 PM   #8
sacramento plumber
wctekkk's Avatar
Location: born and raised in San mateo ca. living in Sacramento Ca for 3 years now.
Rewards Points: 77
slip joint
wctekkk is offline   Reply With Quote
Old 03-30-2013, 12:03 AM   #9
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Waste/overflow assembly
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 03-30-2013, 12:07 AM   #10
Rewards Points: 866
Check your building code. I was told that those slip fitting tub waste drains aren't legal in my state if they are in an enclosed space. They are legal if there is ready access. I had to have one ripped out and replaced with a glued up ABS drain.
Old 03-30-2013, 10:51 AM   #11
Roofmaster
Rewards Points: 2,210
I would never use a slip joint connection under a tub. They are usually inaccessable.
The Following User Says Thank You to jagans For This Useful Post:
Alan (04-01-2013)
Old 03-31-2013, 02:36 PM   #12
Rewards Points: 150
I switched to PVC. Someone said theyre not to code if you dont have an access panel. Which I can see why that would be a good idea.
Sink Drain Stopper Won't Pop Up erclark Plumbing 7 07-11-2009 07:31 AM
Sink drain for new sink. Can't get to plain pipe. rogersmithiii Plumbing 2 07-10-2009 10:24 AM
How to drain a utility sink that is in basement? Mikey Palmice Plumbing 40 01-28-2008 09:11 PM
Sink doesn't drain into Septic but somewhere else? 40s house? Where? twilightcall Plumbing 11 01-18-2008 08:36 AM
Drain placement for sink simonb Plumbing 3 09-08-2007 01:08 PM
