-   -   What is sink drain/tub drain piping called? (http://www.diychatroom.com/f7/what-sink-drain-tub-drain-piping-called-175182/)
Arsinek 03-21-2013 09:05 PM
I was thinking about trying to convert part of my tub drain to the plastic pipe that uses those screw on compression fittings. Id like to know what its called so I can research it.
It says its 1 1/2 inch but its not the same size as 1 1/2 inch pvc pipe.
joecaption 03-21-2013 09:14 PM
http://www.homedepot.com/p/Watts-1-1...-5CP/100677379
Then you use a 1-1/2 adapter.
http://www.bing.com/images/search?q=...ectedIndex=277
Arsinek 03-21-2013 09:21 PM
Thanks.
After looking around it doesnt really seem to have a name. Plastic tubing was the closest thing. Searching for slip joint brought up a lot of stuff.
Ghostmaker 03-21-2013 10:14 PM
Tubular tub waste
Klawman 03-21-2013 11:57 PM
Joe Caption is on the money, again. I just had an old tub pulled and replaced with a new tub and I paid for new ABS "Trip Lever Bath Drain". That is what Watts, the manufacturer, calls the set I bought at Home Depot. I think some call it a waste/overflow line.
zcs20027 03-22-2013 03:56 PM
most people call it polyethylyne
Arsinek 03-22-2013 06:01 PM
Ill have to take a pic of the contraption I came up with. :)
wctekkk 03-29-2013 10:51 PM
slip joint
plummen 03-30-2013 12:03 AM
Waste/overflow assembly:)
Klawman 03-30-2013 12:07 AM
Check your building code. I was told that those slip fitting tub waste drains aren't legal in my state if they are in an enclosed space. They are legal if there is ready access. I had to have one ripped out and replaced with a glued up ABS drain.
jagans 03-30-2013 10:51 AM
I would never use a slip joint connection under a tub. They are usually inaccessable.
Arsinek 03-31-2013 02:36 PM
I switched to PVC. Someone said theyre not to code if you dont have an access panel. Which I can see why that would be a good idea.
