What Should I Do With This Old Saddle Valve? - Plumbing - DIY Home Improvement | DIYChatroom
Old 06-13-2011, 11:34 PM   #1
Rewards Points: 682
What should I do with this old saddle valve?
Behind the refrigerator space is a stu-bout, with a saddle valve attached to it. I have never used it, and am thinking about using it now for a refrigerator icemaker.
Since there is no water coming out of it, it must never have been used before, am I correct?
If so, should I just replace it with a new one and go from there?
Also should I use it at all? A saddle valve seems like a leak waiting to happen.
darsunt is offline   Reply With Quote
Old 06-14-2011, 12:16 AM   #2
Plumber
TheEplumber's Avatar
Rewards Points: 826
You're right, its a leak waiting to happen. Best thing to do is to cut the pipe behind the existing valve and install a 1/2"x1/4" icemaker valve on it. Something like this (You can remove the 1/4" nut and use a braided flex line to the refer.)
What should I do with this old saddle valve?-brass-angle-valve-pipe-union.jpg
Old 06-14-2011, 04:52 PM   #3
Rewards Points: 682
Does this icemaker valve get fixed to the water line by compressing a copper washer like a normal shutoff valve?
Old 06-14-2011, 08:24 PM   #4
DIY staff
Rewards Points: 7,174
Yes--it's a regular compression shut off--just has 1/4" outlet.
Old 06-14-2011, 10:16 PM   #5
Rewards Points: 682
I looked at some ice maker water lines. They have rubber washers on the ends, just like installing faucet water lines. Looks fairly easy.
The Following User Says Thank You to darsunt For This Useful Post:
oh'mike (06-15-2011)
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Re-installing saddle valve on newly installed water heater connections bkraz Plumbing 18 12-16-2010 02:51 PM
Installing saddle valve on hot water pipe Dbizot Plumbing 6 01-14-2010 11:11 AM
can I runa second line from a pre-existing saddle valve? ClancyKev Plumbing 1 10-23-2009 06:02 PM
Best 1/2 inch water shut off valve. Nestor_Kelebay Plumbing 10 07-25-2008 11:16 AM
