what is this septic pipe for and can I "fix" it? (see pictures)
it may be an old drain that was closed off when something was redone above? (hence the occasional stink when outside pressure changes)
what is it connected to at the floor? is that a steel flange? you might keep it as a cleanout at floor level, but if it was made as a cleanout, i think it would have a cap.....
DM
[SIGPIC][/SIGPIC]Click To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. to see some of my original magic tricks and trick boxes!
