What Sealant To Use With Water Heater Flex Lines? - Plumbing - DIY Home Improvement | DIYChatroom
Old 05-23-2010, 11:14 PM   #1
Rewards Points: 682
What sealant to use with water heater flex lines?
I've heard that you should never use pipe thread compound for the flexible water lines running to the water heater, that you should only use teflon tape. Is this true, and why?
Thanks.
darsunt is offline   Reply With Quote
Old 05-23-2010, 11:17 PM   #2
Rewards Points: 682
Or are these flexible copper lines like water lines for sinks, that really don't need any pipe compound or teflon tape at all?
Old 05-24-2010, 12:54 AM   #3
Doing it myself
Alan's Avatar
Rewards Points: 2,086
If they have a gasket inside, you don't need any tape or compound. If it's old and it leaks, the gasket may need replacing. If it's new and it's leaking, you're not tight enough, or way overtight and ruined the gasket.
Journeyman Plumber
Old 08-14-2011, 12:33 AM   #4
Rewards Points: 682
I just replaced a leaking flex line for a water heater that was leaking. The handyman who installed it I have respect for, but he did put a ton of pipe dope around the connection, I don't think it helped.
I did not put any tape or dope on the threads and it is doing fine, thanks.
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Water Heater Problems martyshel Electrical 4 01-24-2009 01:07 AM
Multiple hot water heater issues a-6intruder Plumbing 8 01-16-2009 06:58 PM
Natural Gas Water Heater Leaking from Release Valve Pipe? psumike Plumbing 6 01-14-2009 08:18 PM
water pooling ontop of water heater nannerkrns Plumbing 2 09-23-2008 11:04 PM
