What Is The Required Distance From A Water Line From A Drain? - Plumbing - DIY Home Improvement | DIYChatroom
Old 11-06-2010, 06:38 PM   #1
What is the required distance from a water line from a drain?
I'm roughing in some water lines and drain Pipe for a new bathroom but want to know if they need to be a certain distance apart?
arsurfco is offline   Reply With Quote
Old 11-06-2010, 06:44 PM   #2
Rewards Points: 150
If you are doing this inside just run them where you want without getting in the way of something else; if you are running lines outside then you get into a lot of rules
braindead is offline   Reply With Quote
Water heater drain pan line Bigmike33 Plumbing 1 09-22-2010 09:29 PM
Need to run gas line to Tankless Water Heater. anonymouscuban Plumbing 2 04-16-2010 03:56 PM
Water Backing up Though hole in basement dynamis Plumbing 3 06-15-2009 06:11 PM
Main Supply Line Vibrates When Cold Water Runs kmcbee1971 Plumbing 1 01-13-2009 10:26 PM
Filling a Cast Iron radiator system insulatorpro HVAC 7 10-07-2008 12:31 AM
